Author Topic: how to put delay on this programming?  (Read 484 times)
Offline bahaTopic starter
« on: March 12, 2010, 04:55:03 AM »
hello guys..
i have a big problem to be solve..
i am making robotic arm using PIC 16f784A as main controller.
but my robot movement was really quick.
so i trying to put delay time in my coding.
but i have no idea for now.
can anyone give some idea how i can solve my problem.
TQ so much!!
below is the coding for my pic controller using PIC Basic compiler:
Microcontroller programming using PICBasic Pro Software
TRISB = %00000000
TRISA = %00000001
DEFINE OSC 4
include "modedefs.bas"
Led             VAR PORTA.4
Baud            CON N2400
Com_In         VAR PORTA.0
Com_Out         var PORTA.1
Control         VAR BYTE
Slider          VAR byte
Sync            var byte
I               VAR BYTE
S0              var byte
S1              var byte
S2              VAR BYTE
S3              VAR BYTE
S4              VAR BYTE
S5              VAR BYTE
S6              VAR BYTE
S7              VAR BYTE
low PORTB.0
LOW PORTB.1
LOW PORTB.2
LOW PORTB.3
low PORTB.4
LOW PORTB.5
LOW PORTB.6
LOW PORTB.7
high led
S0 = 127
S1 = 111
S2 = 144
S3 = 65
S4 = 127
S5 = 127
S6 = 127
S7 = 127
Start:
    serin Com_In, Baud, 7, Set_Pos, [255], Slider, Control
    SEROUT Com_Out, Baud, [Slider,Control]
    If Slider = 0 Then S0 = Control
    If Slider = 1 Then
        S1 = Control
        S2 = 254 - S1
    End If
    If Slider = 2 Then S3 = Control
    If Slider = 3 Then
        S4 = Control
        S5 = 254 - S4
    End If
    If Slider = 4 Then S6 = Control
    If Slider = 5 Then S7 = Control
Set_Pos:
    pulsout PORTB.0,S0
    pulsout PORTB.1,S1
    pulsout PORTB.2,S2
    pulsout PORTB.3,S3
    pulsout PORTB.4,S4
    pulsout PORTB.5,S5
    pulsout PORTB.6,S6
    pulsout PORTB.7,S7
GoTo Start
delay
Started by ed1380 Electronics
Last post April 19, 2008, 07:37:57 AM
by benji
Last post July 08, 2009, 12:15:25 PM
by sonictj
delay
Started by jorj Electronics
Last post August 20, 2009, 11:55:26 PM
by Razor Concepts
Last post February 27, 2011, 10:14:30 AM
by hoheiho
