Author Topic: 50 Dollar Robot Upgrade?  (Read 1065 times)
Offline YoungGeniusTopic starter
« on: March 13, 2010, 10:43:45 AM »
How do I build a robot that can follow an IR Emitter or something that might be attached to me? Hence, the robot will follow me?
  • Helpful? 84
Re: 50 Dollar Robot Upgrade?
« Reply #1 on: March 13, 2010, 11:38:13 AM »
This question has been asked a few times here. Just search the forum for discussions.
« Reply #2 on: March 13, 2010, 02:26:51 PM »
Do I replace the photo resisters with with IR Sensors? Will it just follow the IR Emitter or might it steer towards other IR sources?
Offline Joker94
  • Helpful? 26
« Reply #3 on: March 13, 2010, 05:50:37 PM »
no you cant just swap one for the other. The first reason is that the photo resistors give resistance and by that tell the robot to go to right or left. With the emitter and detector you have to have the micro controller know that it needs to detect the ir light coming from you. it cant be a reading that tells it to go right or left.
the principle is they both will need different code to operate as they were intended. the $50 upgrade with the sharp IR sensor sounds like it will do what you want to do.
but if you want to use a IR receiver and emitter LED you may be able to alter the $50 ir upgrade but i am not sure on that as i have not had a close look at it. have a look at the $50 dollar IR upgrade and see what you can gain from reading the code.
Offline cooldog
« Reply #4 on: March 13, 2010, 08:41:31 PM »
you can swap the photocells with IR range finders and they will follow IR light. no code change
-admin
favorite web sites
http://www.instructables.com/
Last post April 20, 2008, 04:43:14 PM
Last post January 26, 2008, 04:12:07 PM
Last post December 02, 2010, 10:33:57 AM
by Crunchy Theory
Last post April 28, 2011, 03:47:57 PM
by knossos
