Author Topic: Lithium Battery Fire  (Read 7667 times)
Offline AdminTopic starter
« on: May 13, 2007, 10:51:05 AM »
what happens when you combine red necks with a lithium battery?
http://video.google.com/videoplay?docid=3690260570423705609
now you know why batteries can be dangerous if not used properly :P
Offline ed1380
Re: Lithium Battery Fire
« Reply #1 on: May 13, 2007, 11:32:54 AM »
pretty cool.
Now you know what I have to live with here in GA :P
Offline megaman935
« Reply #2 on: June 25, 2007, 04:32:54 PM »
GA? try FL! ;D
-I knew I was a redneck soon as I put a bucket in place of the toilet. :P
« Reply #3 on: June 25, 2007, 05:25:14 PM »
Im from LA . . . that state held me back for most of my life . . .  :-[
Offline Brandon121233
« Reply #4 on: June 25, 2007, 06:53:28 PM »
what do you mean by that?
        —Thomas Edison
Offline maverick monk
« Reply #5 on: June 25, 2007, 06:59:09 PM »
i live in the boondocks too (central PA). i realized that when we asked for fireworks for a 4th of july party and 2 ppl brought shotguns...
Offline Eco19R
« Reply #6 on: June 25, 2007, 07:04:08 PM »
Whats wrong with shotguns? ???
Offline KambeiX
« Reply #7 on: July 01, 2007, 03:33:01 PM »
 :o
I think I will be very careful with the LiPos I ordered from bidproduct.com a few days ago...
Offline S. Karim
« Reply #8 on: July 03, 2007, 03:33:29 PM »
lipo isnt the same as lithium ion?
Offline KambeiX
« Reply #9 on: July 03, 2007, 07:47:12 PM »
From Wikipedia:
Lithium-ion polymer batteries, or more commonly lithium polymer batteries (abbreviated Li-poly or LiPo) are rechargeable batteries which have technologically evolved from lithium-ion batteries. Ultimately, the lithium-salt electrolyte is not held in an organic solvent as in the lithium-ion design, but in a solid polymer composite such as polyacrylonitrile. There are many advantages of this design over the classic lithium-ion design, including the fact that the solid polymer electrolyte is not flammable (unlike the organic solvent that the Li-ion cell uses). Lithium-ion polymer batteries started appearing in consumer electronics around 1996.
At least they say LiPos aren't flammable :P
__________
Edit:
Overcharging a Li-poly battery will likely result in explosion and/or fire. During discharge on load, the load has to be removed as soon as the voltage drops below approximately 3.0 V per cell (used in a series combination), or else the battery will subsequently no longer accept a charge.
 :o
« Last Edit: July 03, 2007, 07:49:41 PM by KambeiX »
« Reply #10 on: July 05, 2007, 12:47:32 PM »
the rule of thumb I use:
lithium ion holds a higher charge
lithium polymer has a higher discharge rate
I prefer Lithium ion because I generally never need 30A continuous with Li-po. . .
Offline robotvisionary
  • Lucky I wasn't that driver.
« Reply #11 on: July 08, 2007, 02:33:58 AM »
« Last Edit: July 08, 2007, 07:02:35 AM by robotvisionary »
I've have not failed, I've just found out 2,000 how a light bulb will not work
                              Thomas Edision.
« Reply #12 on: July 08, 2007, 02:38:26 AM »
PLS reply and give my ideas on why i cant see the video or if you also cant see the video. :'(
                              Thomas Edision.
« Reply #13 on: July 08, 2007, 07:00:50 AM »
Well for one you are trying to embed a google video using the youtube embed script ;D
I dont currently support embedding google videos. You will have to just link it. Its one of the thousand things on my to-do list . . .
« Reply #14 on: July 08, 2007, 07:03:06 AM »
fix it
                              Thomas Edision.
Offline megaman935
« Reply #15 on: July 08, 2007, 08:25:54 AM »
fix it
dude- did you not see that he has at least a thousand other things on his mind right now?
Robot Forum
July 2 - Admin has been crazy busy and will remain so for another week. Apologies for slow help!
Offline ed1380
« Reply #16 on: July 08, 2007, 02:16:57 PM »
fix it
Robot Forum
he meant fixed it
Offline megaman935
« Reply #17 on: July 08, 2007, 06:25:53 PM »
Oh.... My apologies sir...
« Reply #18 on: July 08, 2007, 11:16:00 PM »
Sorry typing error haven't been paying much attention to my spelling. :)
                              Thomas Edision.
Offline roboplane2.0
  • Henry the Robot
« Reply #19 on: July 09, 2007, 06:12:30 PM »
What did they do to make it explode?
If you're a Halo Fan, click here http://www.freewebs.com/halowireless/forum.htm.
Offline megaman935
« Reply #20 on: July 09, 2007, 07:25:46 PM »
Overcharging..............................................BOOM..............................................
« Reply #21 on: July 09, 2007, 10:00:29 PM »
They use a transformer to replay what would happend afters days or even weeks or month of charging constantly :D.
                              Thomas Edision.
