Author Topic: Pololu Carrier with Sharp GP2Y0D810Z0F  (Read 1618 times)
Offline richiereynoldsTopic starter
« on: March 15, 2010, 05:09:05 AM »
Anyone bought this product?
http://www.active-robots.com/products/sensors/pololu-carrier-10cm.shtml
They're about £5 each. I bought 2 a couple weeks ago, then one just stopped working so I bought another, then the second one I'd bought stopped working! I didn't think I'd been rough or fried them but I guessed it was probably my fault somehow.
In any case I wanted 4 for a new robot so bought 4 more. Then the other night the 3rd one I bought just stopped working too.
Haven't really used the 4 new ones yet but as the first 3 have just died I thought I'd ask has anyone else had any difficulties with these before I get onto the supplier.
Thanks, Richard.
Re: Pololu Carrier with Sharp GP2Y0D810Z0F
« Reply #1 on: March 15, 2010, 08:54:59 AM »
I am using two of the 5cm versions. So far they have been working.
I did find that they do draw lots of current when switching so put a 47uF cap right on the power pins.
Are you powering them from a regulated supply? Or are there motors connected to the same power as the Sharpe uses? I could see that spikes, from motors, could kill these.
« Reply #2 on: March 15, 2010, 10:17:32 AM »
Hi there, yes they're on a regulated 5V supply with no motors, plus they've got 22uf ceramic caps across power and ground right on the carrier boards.
  • Helpful? 111
« Reply #3 on: March 15, 2010, 08:14:16 PM »
Hi richie
I'm in the UK as well and buy stuff from active robots.
I suggest you also post questions to their support department and see what they say.
Since its a kinda blog then you may get responses from others as well.
« Reply #4 on: March 16, 2010, 06:31:34 AM »
Cheers for the info, I'll do that.
