Author Topic: power problem with sv203  (Read 469 times)
Offline kpTopic starter
« on: March 17, 2010, 08:43:53 PM »
Good day!
I have SV203 board for my robot arm project. When I power on (either battery or power supply through adapter) properly to the board, the servo motor did not return to its neutral position. Instead, the servo motor moves a bit when I touch the terminal to battery on and off. It is kind like it moves a bit incrementally every time we 'actuate' the board with power supply. But I thought the motor should be able to move smoothly to its neutral position continuously when it is powered on. I have checked all the wire connection. There should not be inconstant power supply problem because the same thing happened when we used power supply. Can anyone please advice. Thank you.
Last post June 16, 2007, 05:15:17 PM
Last post February 22, 2008, 11:07:06 AM
by Trumpkin
Last post March 15, 2008, 05:23:34 PM
Last post September 01, 2008, 02:06:07 AM
by reefat
