Author Topic: another $50 robot question  (Read 718 times)
Offline morphixsterTopic starter
« on: March 20, 2010, 04:16:03 AM »
I just finished the $50 robot tutorial and although I don't have a cable to connect to the computer but I'm confused about the LED. Is it supposed to light up when the power is connected or did I miss something along the way?
It looks like the LED resistor is hooked up to a pin on the mega8 so i was wondering if that is on when it's connected to the PC.
Any help would be appreciated
Re: another $50 robot question
« Reply #1 on: March 20, 2010, 05:12:35 AM »
You must program the microcontroller for the LED to turn on.
Offline 123laurens
« Reply #2 on: October 06, 2010, 09:54:03 AM »
like the post above,yes.the command i think was LED_on() and LED_off()
to test,put this in the "main"under /*********ADD YOUR CODE BELOW THIS LINE **********/
while(1);
LED_on();
delay_cycles(23);
LED_off();
delay_cycles(23);
this will cause your led to turn on for 1 second ,then turn off for 1 second ,and so forth until you turn it off
simply replace the code or just add LED_on() at the beginning of your photovore code,replacing the LED_off()
i hope this helps!
« Last Edit: October 06, 2010, 12:02:48 PM by 123laurens »
Last post April 24, 2007, 06:44:22 PM
Last post May 10, 2008, 07:21:03 AM
by shlodo
Last post July 22, 2010, 11:33:20 AM
Last post April 15, 2009, 09:28:45 AM
by GearMotion
