Author Topic: Can someone explain me about this line of code. Please help  (Read 1678 times)
Offline amadordTopic starter
« on: March 22, 2010, 03:25:12 PM »
I have this code inside the photovore program in arduino. I want to learn what it means.
here's the code:
sensor_right = map(sensor_right, 0, 1023, 0, 255);
what does the numbers mean?
Offline dellagd
Re: Can someone explain me about this line of code. Please help
« Reply #1 on: March 22, 2010, 04:09:11 PM »
um, a little more info plz. Can u plz post the code here?
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
« Reply #2 on: March 22, 2010, 05:42:38 PM »
Can you look or post the code for the function map()? That is where the answer may be.
« Reply #3 on: March 22, 2010, 05:54:06 PM »
That is a fancy way of converting a number that is originally from 0 to 1024 (typically ADC reading) to a 0 to 255 value. I believe it is Arduino code.
Offline billhowl
  • Helpful? 32
« Reply #4 on: March 22, 2010, 05:56:33 PM »
map(value, fromLow, fromHigh, toLow, toHigh)
Description
Re-maps a number from one range to another. That is, a value of fromLow would get mapped to toLow, a value of fromHigh to toHigh, values in-between to values in-between, etc.
http://www.arduino.cc/en/Reference/Map
Offline Xyver
« Reply #5 on: March 22, 2010, 07:36:46 PM »
I believe Razor is correct.  Its converting the values from 0-1023 to 0-255.  I assume its for a photovore?
« Reply #6 on: March 23, 2010, 05:51:27 AM »
okay thanks that explains. thank you very much
