Voltage readings with the multimeter indicate that there is no voltage on the signal line, 5+ volts on the power line and 0 volts on the ground (servo connector).
Would the change from Atmega8 to Atmega88PA make a difference at all? Does not having the programmer attached mess up the circuitry in any way?
while(1){ PORTD= 0xFF; //Turn on PortD pins delay_ms(1.5); //Delay 1.5 milliseconds PORTD=0x00; //Turn off PortD pins delay_ms(20); //There may have been another delay here. I can't remember.}
Started by cyclopediatechtilon Electronics
Started by tipipliou Electronics
Started by mjtedin Mechanics and Construction
Started by Robot_Longbordr Mechanics and Construction
