Author Topic: Axon Test Hex 1  (Read 1396 times)
Offline Razor ConceptsTopic starter
Axon Test Hex 1
« on: March 29, 2010, 11:38:28 AM »
I am using an Axon original, trying to upload the text hex file one (toggling all ports). AVR Studio reports that the hex file is not a valid intel hex file. The other examples work, except that first one. Can anyone else verify this? I am using the AVR ISP MKII
Re: Axon Test Hex 1
« Reply #1 on: April 03, 2010, 08:48:34 PM »
Where did you find the .hex?
Possible upload error on my part . . .
Re: Axon Test Hex 1
« Reply #2 on: May 29, 2010, 04:53:09 PM »
Bringin this up again
Here are the two last lines of the hex, last one seems missing parts?
:1009C00050E00E9449028BE295E026E334E0B90151
:1009D00040E150E00E944902CF91DF9108
Error message: :Getting isp parameter.. SD=0x06 .. OKThe specified file is not a valid Intel HEX file
Also what is the default baud rate?
« Last Edit: May 29, 2010, 05:21:07 PM by Razor Concepts »
Re: Axon Test Hex 1
« Reply #3 on: May 29, 2010, 09:01:56 PM »
Again, where did you find that .hex file link? :P
(it looks broken)
For what? If you mean for the $50 Robot, you can specify it in the code. Its all commented.
Re: Axon Test Hex 1
« Reply #4 on: May 29, 2010, 09:54:53 PM »
Re: Axon Test Hex 1
« Reply #5 on: June 04, 2010, 09:03:01 AM »
80% of the file somehow went missing. On both my PC and the web copy . . . but found another copy thats complete so no worries.
http://www.societyofrobots.com/axon/downloads/axon_tst.hex
Let me know how it goes.
Re: Axon Test Hex 1
« Reply #6 on: June 05, 2010, 04:01:03 PM »
"1" and "port" get repeated over and over again without line breaks
Can somebody with an Axon 1 verify this? My Axon has been "re-heated"
Re: Axon Test Hex 1
« Reply #7 on: June 06, 2010, 12:11:17 AM »
Yeap, thats correct. Each UART port transmits its port number, and all the pins should be turning on/off ever second or so.
Last post September 07, 2009, 02:54:14 PM
Last post January 27, 2010, 11:28:46 PM
by bsamuels
Last post February 21, 2011, 11:52:30 AM
by roboSonny
Last post September 09, 2012, 12:18:14 PM
by Silver_79
