Author Topic: Bluetooth Module to PC  (Read 1510 times)
Offline etanhayTopic starter
« on: March 31, 2010, 06:06:00 AM »
I just bought an UART bluetooth module,
I want to build circuit that turn led on and off but I don't know how.
Also I don't know how to connect this module to any physical device and how can I get the result of what that I send via the computer (I see the device as COM4)
It's possible to connect the TX and RX legs of the module to a regular COM port (TX and RX Legs)?
I will be happy to get any kind of help.
Thank you very much,
Etan hay.
Offline Gophermofur
Re: Bluetooth Module to PC
« Reply #1 on: March 31, 2010, 06:59:57 AM »
Did you read the SoR bluetooth page? http://www.societyofrobots.com/electronics_bluetooth_robot.shtml
It might answer some of your questions.
Offline dylouttrim
« Reply #2 on: March 31, 2010, 09:18:14 AM »
hey not sure if u have seen this yet, but it might help as i believe it is what u are trying to achieve.
http://blog.narobo.com/2008/08/bluetooth-controlled-lights.html
« Reply #3 on: March 31, 2010, 10:25:49 AM »
Hello.
Both of the articles are about Axon kit.
I want to know if there is an option to connect the module to PC via COM port RX to TX and TX to RX.
Thank you very much.
« Reply #4 on: March 31, 2010, 03:14:31 PM »
Yes, that is exactly what happens in the bluetooth tutorial =)
The concept is pretty much the same with most atmegas.
To start, open up hyperterminal and connect to com4 if that's what it is and see if you can send/receive any data.
« Last Edit: March 31, 2010, 03:15:43 PM by SmAsH »
Offline gossamer
« Reply #5 on: April 01, 2010, 06:14:33 AM »
Have in mind that serial port is 15v and UART is ttl (5v). so you need conversion via max232 or similar chip.
« Reply #6 on: April 01, 2010, 10:49:27 AM »
You just redefined the term "Gross Overkill"  ;D
A simple set of TX/RX modules is close to Plug 'N' Play, while the Bluetooth will probably be mmore like Plug 'N' Pray.
But hey, as long as that LED are gonna shine  ;)
