Author Topic: VNH3SP30 with 3.3V controller?  (Read 1557 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
« on: April 01, 2010, 12:26:16 PM »
Hi All,
I need a sanity check here.  Is it possible to use a 3.3V Atmel chip with the VNH3SP30?
http://pdf1.alldatasheet.com/datasheet-pdf/view/84563/STMICROELECTRONICS/VNH3SP30.html
I'm a little confused form their 3.25V test data and the other information in the data sheet.
I'd really appreciate your help!
Mike
Re: VNH3SP30 with 3.3V controller?
« Reply #1 on: April 01, 2010, 12:54:17 PM »
As long as the h-bridge itself is being powered by at least 5.5 volts, the 3.3v logic level high sent by the atmel chip should control it fine.
« Reply #2 on: April 01, 2010, 12:58:33 PM »
The INA , INB and PWM are at 5V
The Enable/Diag pins are at 3.3V
For some reason this doesn't turn on the motor.
The strange things is that when I cycle the VCC power, the motor starts to work.
Any ideas?
« Reply #3 on: April 01, 2010, 05:14:22 PM »
The 3.3V is in itself pretty close to the 3.25V. Add the hysteresis of 0.5V and it's going on one wing and a prayer.
You could use small signal transistors and pull ups, or a (6x or 8x) buffer/level translator circuit to get the voltages in check.
