Author Topic: Solved: Issues with Makefile (Axon + Ubuntu)  (Read 3499 times)
Offline RyltarTopic starter
« on: April 01, 2010, 03:31:16 PM »
Hello,
I am currently working on a new robot using the Axon. When my Windows XP system still function, I was able to program the Axon easily. I am now on a Ubuntu system (9.10) and am having issues. I looked around first and found the topic "HOW-TO Axon with Ubuntu". Following the guide there, I've managed to get all the components set up. I can even talk to the Axon using minicom.
My issue arises during the building of the hex file. I try to use the default makefile included in Admin's source code and I get the following message"
glitchtech@ronin:~/Desktop/Robotics/AxonOne$ make
.dep/a2d.o.d:1: *** multiple target patterns.  Stop.
When I try to use the shorter makefile in the topic, I get this error:
glitchtech@ronin:~/Desktop/Robotics/AxonOne$ make build
Compiling a2d.c...
make: *** No rule to make target `main.o', needed by `AxonOne.bin'.  Stop.
If I remove the reference to main.o then I get:
Compiling buffer.c...
Compiling rprintf.c...
Compiling timer640.c...
Compiling uart4.c...
Linking a2d.o buffer.o rprintf.o timer640.o uart4.o to AxonOne.bin...
/usr/lib/gcc/avr/4.3.3/../../../avr/lib/avr5/crtm640.o: In function `__bad_interrupt':
../../../../crt1/gcrt1.S:193: undefined reference to `main'
make: *** [AxonOne.bin] Error 1
I'm not having any luck figuring out what to do now. Anyone able to help me work these kinks out?
Thanks for any help. I guess if worse comes to worse, I can see about moving back to windows  :-\
« Last Edit: April 02, 2010, 03:42:10 PM by Ryltar »
Offline chelmi
  • Helpful? 15
Re: Issues with Makefile (Axon + Ubuntu)
« Reply #1 on: April 01, 2010, 04:53:27 PM »
do you have a main.c file in your directory?
« Reply #2 on: April 01, 2010, 05:29:05 PM »
Adding a main.c (main.h too) file causes the same error as removing the reference to main.o. I made sure to make clean first as well.
Compiling a2d.c...
Compiling main.c...
Linking a2d.o main.o buffer.o rprintf.o timer640.o uart4.o to AxonOne.bin...
Looking at the error, I'd almost say that there is an issue with my avr library, but what do I know... I'm still new to this.
Looking into the error "../../../../crt1/gcrt1.S:193: undefined reference to `main'", it seems like the compiler cannot find my main function (in the file AxonOne.c), though the function does exist.
« Last Edit: April 01, 2010, 05:40:02 PM by Ryltar »
Offline chelmi
  • Helpful? 15
« Reply #3 on: April 02, 2010, 09:42:02 AM »
Yes.
what do you have in main.c ?
Your file AxonOne.c is not part of the list of compiled files, try adding a reference to it.
« Reply #4 on: April 02, 2010, 10:36:12 AM »
I was leaving the main.c empty. I tried adding axonone to object list but no joy. So I went back and started from scratch with the latest release of the Axon source code. I was able to get it functional. I'm not sure what I would have done to fix the makefile/my code though.
Now I am going to work on getting Admin's makefile to properly program the bot with the make build command.
Thanks for your help chelmi.
« Reply #5 on: April 02, 2010, 03:41:48 PM »
Just an update on this. I'm able to program the Axon using a slightly modified version of Admin's makefile on Ubuntu. Now on to the next task: getting it to move correctly :)
Re: Solved: Issues with Makefile (Axon + Ubuntu)
« Reply #6 on: April 03, 2010, 08:39:37 PM »
Just in case someone else has the same problem, please share :P
« Reply #7 on: April 04, 2010, 06:42:14 PM »
Oh heh. Probably would be a good idea. You will need to change the DEVNODE variable to match which port your USB/Axon connection is using. Make sure you follow the rest of the guide given in the first post. Couldn't have done it with out that.
« Last Edit: April 04, 2010, 06:43:38 PM by Ryltar »
Last post May 31, 2011, 08:42:20 AM
by adanvasco
Last post June 27, 2009, 08:27:51 PM
Last post December 02, 2009, 09:56:35 AM
by taba93
Last post May 31, 2011, 06:17:51 PM
