Author Topic: "C" brackets ?  (Read 814 times)
Offline JohnBotTopic starter
"C" brackets ?
« on: April 03, 2010, 08:51:58 AM »
Anyone know where I can find "c" brackets that are a bit bigger than standard. Ideal dimensions would be about 8 inches wide and roughly 5 inches deep. I've checked a bunch of places, including all sorts of servo mounts / bracket suppliers, but no luck.
I'm trying to make (or buy) an inexpensive tilt. Exactly like a standard pan and tilt- but without the pan. Also, this will not be operated by a motor / servo. It will need to manually tilted, and then locked in place.
I'm hoping to accomplish by taking two "c" brackets -one slightly wider than the other, then lining up the axle holes and putting a screw through. This will create a joint. Then I'll simple put a bolts on the end and tighten (think this will work?). L-Brackets could also be made to work, but I'd prefer two ready made "c" brackets or an existing inexpensive tilt.
Exactly like these, only bigger:
http://www.active-robots.com/products/motorsandwheels/servo-motors/asb09-750.jpg
  • Helpful? 84
Re: "C" brackets ?
« Reply #1 on: April 03, 2010, 09:37:56 AM »
Hardware store, construction supply store.
McMaster-Carr
Re: "C" brackets ?
« Reply #2 on: April 03, 2010, 10:48:42 AM »
Sounds like a bracket used for mounting Walkie-Talkies in cars may suit you.
Wouldn't be hard to make one yourself either.
Most important parameter is how much weight it's supposed to carry.
Last post November 28, 2006, 09:08:18 AM
Last post June 17, 2008, 02:33:27 AM
by photray94
Last post March 25, 2009, 12:12:53 AM
by pomprocker
Last post January 02, 2010, 04:36:54 PM
by SmAsH
