Author Topic: Modify HS-422 for continuous rotation  (Read 2191 times)
Offline mjtedinTopic starter
« on: April 10, 2010, 09:05:43 PM »
I ordered HS-311's from ServoCity and they automatically upgraded me to the HS-422's (lucky me).  I want to modify them for continuous rotation, but the pin on the pot is metal and I can't just snip it off like the tutorial says.  I found some hacks online that involve removing the pot entirely but it involves replacing it with resistors that I would have to solder in.  Is there an easier way to disable the pot without soldering resistors in?  Would simply supergluing it be sufficient?
Re: Modify HS-422 for continuous rotation
« Reply #1 on: April 11, 2010, 07:57:05 AM »
I personally superglue it in, but as for the pin, you should be able to pull it out with pliers.
« Reply #2 on: April 13, 2010, 03:05:43 PM »
If all else fails, a file is still a valid tool  :)
« Reply #3 on: April 13, 2010, 04:26:17 PM »
*Cough* Angle grinder *Cough*
Offline amando96
« Reply #4 on: April 15, 2010, 03:38:31 PM »
that's way over kill
dremel!!!
Rorcle, 60% complete
AATV, 5% complete
Last post August 03, 2009, 06:25:07 PM
by wil.hamilton
Last post September 14, 2009, 10:47:25 AM
by GearMotion
Last post March 26, 2010, 01:09:47 PM
by Gophermofur
Last post July 28, 2011, 10:57:58 PM
by Robot_Longbordr
