2
Author Topic: Simple number conversion/ math problem?  (Read 1154 times)
  • Helpful? 11
« on: April 10, 2010, 10:27:07 PM »
I can't seem to find out why this isn't working.  I'm trying to implement something into a program of mine, and using variables does not work.  If I put the value of the variable in, it'll work.  Well, here's the code.
What I tried to use was an array to take place of the values in my code, however it just didn't work.  I guessed that it had something to do with double and int, so I tried to make the first array "a" a double, and the second array "b" was int, then covert the double to the int, but that still didn't work.
This WORKS:
for(ct=1;ct<2000;ct++)
if (ct<=255)
if (ct == 1)
DDRD|=(1<<PORTD0); //LED1 On
OCR1A++; //LED1 brightness up
else if ((ct>255) && (ct<=510))
if (ct == 510)
DDRD&=~0x01; //LED1 Off
OCR1A--; //LED1 brightness down
This does NOT work:
unsigned int ct=1,i,a[17],max,interval;
double num;
max = 1360;
num = 16/3;
interval = max/num;
for(i=0;i<17;i++)
a[i]=(i/3)*interval;
if (ct<=a[3])
if (ct == a[0]+1)
else if ((ct>a[3]) && (ct<=a[6]))
if (ct == a[6])
I even tried this:
unsigned int ct=1,i,b[17];
double num,max,interval,a[17];
max = 1360;
num = 16/3;
interval = max/num;
for(i=0;i<17;i++)
b[i]=(int)a[i];
if (ct<=b[3])
if (ct == b[0]+1)
else if ((ct>b[3]) && (ct<=b[6]))
if (ct == b[6])
What's going on?
« Last Edit: April 10, 2010, 10:38:22 PM by corrado33 »
Offline tim_wang
Re: Simple number conversion/ math problem?
« Reply #1 on: April 11, 2010, 05:47:37 PM »
The problem with your code is that you are dividing unsigned ints which returns unsigned int.
double num;
max = 1360;
num = 16/3; // num = 5, not 5.33!
interval = max/num; // 1360 / 5 = 272, not 255!
for(i=0;i<17;i++)
      a=(i/3)*interval; // a = [0 0 0 272 272 272 544 544 544 816 816 816 1088 1088 1088 1360 1360 1360]
