Author Topic: Building 50$ robot Micro Controler Webbot's version  (Read 1960 times)
Offline huevonTopic starter
« on: April 20, 2010, 03:21:57 PM »
Hi all
Am curently building webbots version of the 50$ robot micro controler. I realy liked the idea to design the board more universal. So far so good acording to PCB etching and soldering components but have a little question. Why on the PCB layout in the .pdf all ADC pins are shorted and on the schematics are not. Please excuse my lame questin as probably there is a good reason for that.
Thank you
Offline chelmi
Re: Building 50$ robot Micro Controler Webbot's version
« Reply #1 on: April 20, 2010, 05:51:00 PM »
I noticed on your layout that you mention the ATMega 168. Please note that the Webbotlib barely fits and you won't be able to do much with the remaining memory.
http://www.societyofrobots.com/robotforum/index.php?topic=10760.msg81754#msg81754
  • Helpful? 107
« Reply #2 on: April 20, 2010, 07:46:51 PM »
@chelmi - 'huevon' is talking about my $50 Robot PCB design - not WebbotLib. ie its a hardware question - not software.
Its the ground pins on the headers that are all connected together, and the power pins are all connected together, the signal pins are not shorted.
The ground pins are the outermost, then the power pins, and the signal pins are innermost.
« Reply #3 on: April 20, 2010, 07:55:14 PM »
I'm looking at the attached PDF and 6 signal pins are shorted together where the headers are?
Offline chelmi
« Reply #4 on: April 20, 2010, 08:11:47 PM »
Woops, my mistake :p
  • Helpful? 107
« Reply #5 on: April 20, 2010, 09:17:00 PM »
Yep - you are right ! What the ..!  I have built this board and it works just fine. Eagle seems to be making the pads too big and hence they 'short'. Perhaps its got clobbered by different Eagle versions.
Will fix and upload a new version
EDIT: Aaarghh Eagle must be the most unfriendly program on earth! How can I change the header pins to leave them where they are and just change the pad size???? Their existing pad size is not friendly as it means any rows of headers at 0.1" pitch will create shorts !!
« Last Edit: April 20, 2010, 10:12:36 PM by Webbot »
« Reply #6 on: April 21, 2010, 02:46:02 AM »
So sory for the headache I'm giving you Webbot.
Thank you all for your replies, it will take just few min to separate the pads :)  On the PCB I mean, don't know how is done in eagle. In fact the PCB layout is very clearly designed and well optimized. If you don't want just to build the 50$ robot and finish with the robotics I recommend building Webbots version of ATmega MCU. It is a good electronics project and you can use it in the future to control even more servos. If you already have some equipment at home and spend money for the components only it will hardly go over £20.
Rasor Concepts do you think there will be enough memory for webbotlib if I use ATmega 328 instead of 168?
  • Helpful? 107
« Reply #7 on: April 21, 2010, 03:53:50 AM »
Yep the 328P is much better - and not much difference in price.
« Reply #8 on: April 21, 2010, 04:08:05 AM »
I personally use the sparkfun library, they have the smaller circular  headers instead of the longpads.
« Reply #9 on: April 21, 2010, 05:37:17 AM »
I found some in www.coolcomponents.co.uk for £2.25 each(may be about $3.70). I find them pretty inexpensive, but what the experts think?
P.S
hehe someone will have to write a special tutorial for me how to use quotations in the SOR forum :P
« Last Edit: April 21, 2010, 05:41:23 AM by huevon »
  • Helpful? 107
« Reply #10 on: April 25, 2010, 10:37:29 AM »
@huevon
Got round to posting a new zip file with 'no overlaps'. Also added a PDF of the Top view.
When using the PCB pdf don't forget that depending on which PCB method you are using then you "may" need to 'flip' the PDF over to create a mirror image
« Reply #11 on: April 25, 2010, 03:12:40 PM »
Cheers Webbot
I actualy had etched the PCB before writing in the forum using toner transfer method but noticed the shorted pins before soldering. Easely fixed the problem with a paper knife after you confirmed my worry. Now everything is soldered in place and can't wait for my programmer to arive.
Any way you have done realy good job which helped me a lot.
Big thanks to all sor members as well
Last post January 27, 2007, 06:44:18 PM
Last post January 03, 2009, 01:16:31 PM
by Webbot
Last post April 15, 2010, 09:06:41 AM
by Cristi_Neagu
Last post May 11, 2010, 10:26:33 PM
