Author Topic: Force Sensor to Servo  (Read 891 times)
Offline ImignantTopic starter
« on: April 25, 2010, 02:00:25 PM »
Hello from Iraq,
I am, or was, building an RC arm with grippers.  I want to use CH 7, which is only an off and on switch, to control the gripper.  My only focus for now is to pick up a full coke can.  I want to connect a FSR to the servo so I can flip the switch and have a controlled grab on the hand.  As is, I have to set the servo at a certain angle which is stressing the servo.
I found a FSR with three leads, is there any way to connect this directly to the servo, as in the potentiometer leads, or do i need some sort of circuitry, or MCU.
Been flying planes for a while but I'm brand new to the microcontroller word.
trying to have it all figured out by the time I go home.
here's the link http://www.trossenrobotics.com/flexiforce-25lb-resistive-force-sensor-4inch.aspx?feed=Froogle
Re: Force Sensor to Servo
« Reply #1 on: April 25, 2010, 05:25:31 PM »
No, you'd need further circuitry.
The FSR gives out a varying voltage (if used as a potential divider) or a varying resistance, while the servo needs a Pulse Width Modulated signal (Google "Servo signal" to learn more).
It would be much easier for you to use a common DC motor and let the button control a circuit that engage/disengage that and you can get rid of the FSR by just limiting the max. current the motor is allowed to draw (that's how torque control works in most handheld battery drills).
Last post July 16, 2007, 02:38:44 AM
by hazzer123
Last post July 21, 2010, 09:51:32 AM
by sam_caro
Last post January 13, 2011, 10:09:48 AM
Last post January 18, 2013, 04:39:19 AM
by mjrobotics
