1- read many different sensors2-turn on and off different components
3-Setup the communication so that I can use wireless communication between the micro controllers and have the data sent wirelessly (Zigbi...?) My only issue is how do I protect the sensors and how can I make these things work together.
I am trying to setup a micro controller so that it would read different sensors
and based on that it would turn certain things on.
I would like to setup many of these micro controllers, so the cost has to be cheap eventually but for now I am interested in setting up a couple of demos.
in short here is what I would like to accomplish.1- read many different sensors2-turn on and off different components3-Setup the communication so that I can use wireless communication between the micro controllers and have the data sent wirelessly (Zigbi...?)
The Bogeyman?
Making them work together seems to be an issue to deal with later on, first you need to find out what needs to go where and what it should accomplish in a single module. When you have a couple of modules working their base functions you can start making them cooperate.
Agreed, start with the basics, and work your way up.
build a field robot that will take those measurements for me from many different locations in the field
Started by anilg Electronics
Started by bryan922 Electronics
Started by bhsmith Electronics
Started by Jdog Robot Videos
