Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
and is it possible to connect the battery to roboduino using a 3-pin female connector or only using a male power plug?
will a 7.2v 2000mAh battery pack be enough if i add a hitec hs311 servo
but doesn't the roboduino regulate the supply of power to the servos? I thought the roboduino restricts the flow to 6v,
As a side note, the 168 isn't really supported by WebbotLib anymore (due to memory limitations you won't be able to do much). Webbot had a choice between file size and program quality, and he chose the latter.
Started by Hawaii00000 Electronics
Started by offy Electronics
Started by jamort Electronics
Started by RICEKING212 Misc
