2
Author Topic: Roboduino/arduino  (Read 5632 times)
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Roboduino/arduino
« Reply #30 on: May 09, 2010, 05:29:53 AM »
You don't need a hardware programmer. Roboduino can be used as a hardware programmer to program a blank mega328 installed on a breadboard with just a crystal, caps, pull up resistor and ISP connections. You will use the regulated 5V from Roboduino to power the mega328. Take a look here:
http://arduino.cc/en/Tutorial/ArduinoISP
Offline Webbot
  • Helpful? 111
« Reply #31 on: May 09, 2010, 12:37:13 PM »
What is the webbotlib anyway and is it a problem if the 168 isn't supported by it? ???
See http://webbot.org.uk
The 168 is supported but you wont fit much onto it - hence ATMega328P gives you at least another 16k for your own program.
Offline Ro-Bot-X
  • Helpful? 25
« Reply #32 on: May 09, 2010, 12:44:21 PM »
Dude, just get a Roboduino and start working with it! After you fill up the mega168, you will have enough experience to burn a bootloader in a blank 328. Admin was right in the previous post that you will need a hardware programmer if you decide to use Webbotlib, as you need the space the bootloader is using. So just get a board, start using it with Arduino, build a robot, then go for something more complicated.
Offline Adityav95Topic starter
« Reply #33 on: May 10, 2010, 03:40:17 AM »
yeah, i think i'll just use the stock atmega 168 that comes with roboduino and think about the 328 with webbot compatibility later, i think 16k is more than enough for this build.  :)
« Reply #34 on: September 08, 2010, 05:00:22 AM »
hey guys just check this battery out:
http://www.all-battery.com/6v2000mahnimhsidebysiderxreceiverbatterypackswhitecconnector11106.aspx
any idea on a charger that will work with 220-240v(approx) to charge this battery pack??
need to charge this thing to get it working. not willing to spend more than $10
Thnk u
