Author Topic: How is on board soldering done ?  (Read 2177 times)
Offline roborgTopic starter
« on: May 05, 2010, 06:51:31 PM »
I was trying to solder few wires to a small bi-polar stepper motor with 4 pins/lead blobs. Had I bought this motor separately it would have come with wires, but in my case I plucked this from old floppy drive and it has 4 pins/solder-heads (small blobs). I wanted to solder jumper cables to these blobs so I can hook this motor to breadboard but they are so close to each other it is becoming difficult to solder wires without short circuiting them. I have been examining few boards and there I can see soldering was done pretty cleanly even when the pins are very very close. How is it done normally ? If I can't solder the wires this motor is pretty much useless to me. Please send me suggestions or easy workarounds. If you want I can post pictures of what I am talking about.
Thanks,
RO.
Offline corrado33
  • Helpful? 11
Re: How is on board soldering done ?
« Reply #1 on: May 05, 2010, 06:54:03 PM »
If you're asking how things like floppy drives and stuff are soldered so nicely...  Well, I'm going to guess it's all soldered by machines.
« Reply #2 on: May 05, 2010, 06:57:39 PM »
well some folks build custom boards/shields for their hobby projects ... how about them ?
Thanks,
RO.
Offline rbtying
  • Helpful? 31
« Reply #3 on: May 05, 2010, 07:42:13 PM »
They use a solder wick.
« Reply #4 on: May 05, 2010, 11:51:02 PM »
Nah, it's a question of using the right tool (a fine point iron), a steady hand, just the right amount of solder and pre-tinned wire of the right gauge.
But... When you compare the motor pads to regular boards, I kinda get the idea that those pads aren't all that small after all - what size are your pads and what is the minimum distance between them?
Anything from 2mm pads with 0.5mm between them and up is quite trivial for a trained hobbyist.
« Reply #5 on: May 06, 2010, 06:14:06 AM »
When I have wires that close, I use heat shrink to insulate everything.
See the pics here:
http://www.societyofrobots.com/schematics_photoresistor.shtml
Offline kd5kfl
« Reply #6 on: May 07, 2010, 09:47:50 PM »
factories use wave soldering. board slides alonf a track over a pot of molten solder. solder is agitated into standing waves. like this...
wavesoldering
Offline corrado33
  • Helpful? 11
« Reply #7 on: May 09, 2010, 12:00:40 PM »
That's cool!  I'm guessing flux is sprayed on?  Then the solder only touches the tips of the pins and flows to the coldest point (the board) thus creating a nice joint?  If so then... cool!
Chuckt
  • Guest
« Reply #8 on: May 09, 2010, 05:43:39 PM »
It sounds like you are talking about surface mount soldering.  It requires flux, fine tipped tweezers, a soldering iron with a fine pitch, an exacto knife and a magnifying device.  They suggest using a chizel soldering iron (1/32nd of an inch) because it can hold the solder and they generally want you to have a temperature controlled iron.  When it doesn't work, you need to remove the solder with solder wick.
There are youtube tutorials online and I'm still learning.
Surface Mount Soldering 101
« Last Edit: May 09, 2010, 05:45:47 PM by Chuckt »
