Author Topic: Hitec Servo  (Read 1041 times)
Offline Adityav95Topic starter
Hitec Servo
« on: May 10, 2010, 05:38:50 AM »
1) i would be pleased if someone would tell me which of these servos is the easier one to modify:
    the Hitec hs-425bb or the hs-311?
2) What is the difference or what makes the difficult to modify servo more difficult to modify than the other?
Offline Imignant
Re: Hitec Servo
« Reply #1 on: May 11, 2010, 02:25:34 PM »
there is a HiTec  Rotation Modification Difficulty List, I cant remember where I got it but I'm sure you can google it.  Lucky for you I put it into Word, the 311 gets a difficulty rating of 5 and the 425 gets a rating of 1.
Difficulty: 1 is the easiest, 10 is the hardest.
1-3 rating: Some very slight modifications.  Trimming of plastic with a knife or dremmel.
4-6 rating: Trimming of plastic with a knife or dremmel. Drilling out of final gear/spline.
7-9 rating: Pulling or tapping out of metal pin from metal spline gear.  Possible soldering.
10 rating: Drilling out of spline gear. Trimming inner case stops. Trimming spline gear stops. Possible soldering.
anything up to 6 is pretty easy even for a beginner.
have fun
