Author Topic: Easiest way to compile  (Read 679 times)
Offline Razor ConceptsTopic starter
« on: May 10, 2010, 03:15:09 PM »
I have:
  • A single C file
  • A single makefile for that file
What would be the easiest method to compile it and get a .hex file out of it? AVR Studio isn't really working out.
Re: Easiest way to compile
« Reply #1 on: May 11, 2010, 05:14:44 AM »
Whats wrong with AVR Studio?
The easiest method would be following the $50 Robot tutorial :P
You can also run gcc (the compiler) as a standalone without AVR Studio. If you google around you'll find instructions.
« Reply #2 on: May 11, 2010, 10:22:31 AM »
Thanks, I figured out how. Use command prompt to get to the directory where the c and the makefile is located, and just type in "make" and it should do its job. I'm compiling arduino bootloaders so I had to type in "make mega" or "make lilypad", etc etc
Offline Cristi_Neagu
« Reply #3 on: May 11, 2010, 12:27:46 PM »
It's sort of related: there's an "open command window here" plug-in on the net. When you right click on a folder, in the menu you get "Open command window here". It opens a command prompt pointing to that folder. Much easier than getting there from c:\>.
  • Helpful? 107
« Reply #4 on: May 11, 2010, 05:24:02 PM »
If you use WebbotLib Project Designer under Windows then it can create the AVR Studio project file for you - with all necessary libs linked in and the correct processor set. All you have to do is click the compile button.
Last post October 07, 2008, 11:03:40 PM
Last post December 07, 2008, 08:57:32 PM
by silo_xtreme
Last post September 15, 2009, 04:55:50 PM
Last post May 24, 2010, 04:17:33 PM
