Author Topic: AXON2 and SD21 servo controller  (Read 2058 times)
Offline teoxanTopic starter
« on: May 13, 2010, 03:23:58 PM »
I interfaced the Devantech SD21 servo controller with the Axon2 using Webbotlib.
The SD21 accepts 21 RC servos, uses I2C interface and it's great for animatronics.
It requires separate power ( 6V-7.2V), it has a socket for a Picaxxe or BS2 microcontroller and it offers 3 I2C sockets so you can plug other I2C devices from Devantech.
For more info please check: http://www.robot-electronics.co.uk/htm/sd21tech.htm
Below is the code I used. I plugged a simple "no name' servo" and I just sent a "speed" command.
You controll a servo by using its address and "speed" command, that may be different depending on the servo.
#include "sys/axon2.h"
#include "rprintf.h" //use for UART
#include "i2c_master.h" //use for I2C
#include "myhardware.h" // user includes
uint8_t address=0xC2; // I2C address for SD21
uint8_t ser[1]={0x3F}; // address of first servo
void appInitHardware(void)
uartInit(USB_UART, USB_BAUD);//USB
    rprintfInit(USB_ACTIVATE);   // just to write a little output-you don't need that actually
rprintf("\nAxon Initiated.\n\n");
return 0;
TICK_COUNT appControl(LOOP_COUNT loopCount, TICK_COUNT loopStart)
i2cMasterSend(address,128,ser); //send 128 to center the servo- may differ in other servos
if (i2cMasterReceive(address,128,ser)) //all is ok?
rprintf("servo 1 centers"); // servo 1
delay_ms(400);
    else
     rprintf("No responce\n");
Next project is to interface the ultrasonic sensors  SRF02 and SRF08.
Theo
Last post October 19, 2007, 08:17:21 PM
Last post July 05, 2008, 08:13:31 AM
Last post May 30, 2010, 02:20:06 PM
by teoxan
Last post September 09, 2012, 07:05:34 PM
by tzankoff
