Author Topic: pulse width modulation and sharp IR sensor  (Read 1975 times)
Offline flamesTopic starter
« on: May 14, 2010, 08:44:22 AM »
hi guys, im new in robots
can anyone help me about the very basic of the pulse width modulation and its formula?
and also, i'd like to ask about the accuracy of a sharp IR sensor. how wide does the beam of this sensor diverge?
  • Helpful? 84
Re: pulse width modulation and sharp IR sensor
« Reply #1 on: May 14, 2010, 10:50:32 AM »
Look at the data sheets for the Sharp IR sensors. The beam width information is there.
In what context? Motor drive, data encoding?
Do you try googling this?
Offline GearMotion
  • Helpful? 24
« Reply #2 on: May 14, 2010, 11:17:03 AM »
Look up Pulse Width Modulation in wikipedia. Their entry page should give you enough information to have a basic understanding.
http://en.wikipedia.org/wiki/Pulse-width_modulation
  • Helpful? 107
« Reply #3 on: May 14, 2010, 11:31:57 AM »
« Reply #4 on: May 14, 2010, 07:23:44 PM »
in the context of motor drive. what i can only understand is that this PWM method is used to control the speed of the motor, but how does it really work. and is there any formula regarding to this method?
Offline corrado33
  • Helpful? 11
« Reply #5 on: May 14, 2010, 07:31:28 PM »
It basically turns the motor on and off really fast.  Think about it, if you turn a light on and off really really really fast (faster than you could do), it would appear dimmer than if it was just on.  The more you have it on the brighter it would be, and the less you have it on the dimmer it would be.  The same thing with a motor.  The "duty cycle" determines how long it's ON and how long it's OFF.  A 50 50 duty cycle is on half of the time off half of the time.  A higher duty cycle would make the motor go faster, and a lower duty cycle would make it go slower.
This sounds like a homework question?  If it is, you should really be doing it yourself.
« Reply #6 on: May 15, 2010, 08:53:39 PM »
thanks for the explanation.
this is a project, but we are required to know how to control the speed of the motor using PWM and the formula behind it.
Last post November 29, 2007, 05:57:55 AM
by Fredrik Andersson
Last post December 13, 2007, 11:01:46 AM
Last post February 21, 2009, 09:03:51 PM
by aruna1
Last post April 01, 2012, 06:11:28 AM
by scorp84
