Author Topic: SRF08 - SRF02 and some AXON I2C issues  (Read 1832 times)
Offline teoxanTopic starter
« on: May 14, 2010, 12:08:48 PM »
I'm trying to write some code to use the AXON2 and the SRF02-SRF08 ultrasonic rangers ( they both have the same i2C address and commands).
I have writen some code for the Wiring microcontroller ( the father of Arduino - they use the same "language") and it works great.
I used the same algorithms and steps in AXON2 using the Webbotlib, but I have a couple of issues:
1. The command to start a reading is not actually working, although it seems that code-wise it's accepted. I don't know what seems to be the problem, but in some point
    I need to stop the I2C transmission and start it again so I can read the registers that hold the actuall reading.
    I'm not very familiar with the inner works of Webbotlib since i'm new to AXON, but I think there must be a "start"-"stop" commands for I2C interface.
2. The reading results come in two bytes ( high-low) , I overpassed this by using  unsigned char types, since there's no "byte" type, but there's nothing to read there
    since the I2C reading command is not working.
A couple of months ago, I interfaced the TPA81 and submitted the code here, and everything works fine with this sensor.
But the SRF02 gives me a real headache.
Below is the code.
Any help will be appreciated!!
// SRF02 - SRF08 Test
#include "sys/axon2.h"
#include "rprintf.h" //use for UART
#include "i2c_master.h" //use for I2C
#include "myhardware.h" // user includes
uint8_t address=0xE0; // I2C address for SRF02 - same as the SRF08
uint8_t command[1]={0x00}; // command to start ranging
unsigned char rangebyte_high[1]={0x02}; //ranging data high byte
unsigned char rangebyte_low[1]={0x03}; // ranging data low byte
uint8_t unitbyte[1]={0x51}; // ranging unit in cm -use 0x50 for inches -and 0x52 for ms
unsigned int range;
unsigned char result[2]={0,0};
void appInitHardware(void)
uartInit(USB_UART, USB_BAUD);//USB
    rprintfInit(USB_ACTIVATE);
rprintf("\nAxon Initiated.\n\n");
return 0;
TICK_COUNT appControl(LOOP_COUNT loopCount, TICK_COUNT loopStart)
i2cMasterSend(address,1,command); //command to initialize module
i2cMasterSend(address,1,unitbyte);// start ranging in cm
delay_ms(70);                    // wait to complete ranging
if(i2cMasterReceive(address,1,unitbyte)) // if it's ok
rprintf("Command for cm 0x51 sent\n");
i2cMasterSend(address,1,rangebyte_high);   // request high byte first
     i2cMasterSend(address,1,rangebyte_low);   // request  low byte
if(i2cMasterReceive(address,1,result)&&(i2cMasterReceive(address,1,result)
rprintf("range: ");
range=result[0]<<8;  // shift high byte left to make room for low byte
range+=range+result[1]; // and add low byte
         rprintf("%d\n", range);
delay_ms(400);
    else
     rprintf("No responce\n");
 return(1000);
Offline Webbot
  • Helpful? 107
Re: SRF08 - SRF02 and some AXON I2C issues
« Reply #1 on: May 15, 2010, 09:41:10 AM »
Think it should be more like this:-
// Define device I2C address
#define ADDR 0xe0
uint8_t range[] = { 0, 0x51 }; // Set command register to 0x51 to start ranging in cm
uint8_t response[4];               // Read 4 register values back
-- in appControl --
i2cMasterSend(ADDR, sizeof(range), range); // start ranging
delay_ms(70); // Wait till its done
if( i2cMasterTransfer( ADDR, 1, range, sizeof(response), response) ){
  // response[0] = software version or 255 if still ranging
  // response[1] = the light level or 0x80 on SRF02
  // response[2] = high byte of range
  // response[3] = low byte of range
  uint16_t value = response[2];
  value <<= 8;  // Move to high byte
  value |= response[3]; // add the low byte
  // Distance is now in the 'value' variable
Once you got it working then I'd recommend removing the 'delay' and instead test if response[0] == 255 which indicates the ranging is still happening. Once you get a valid value back then store it in a global variable and start a new ranging. Therefore the device will constantly be ranging and you will have stored the last 'received' value into the global variable.
« Reply #2 on: May 17, 2010, 09:07:52 AM »
I tested the coade and it's working ok! :)
Thanks!
Theo
Last post March 15, 2009, 09:19:54 AM
Last post October 07, 2010, 02:12:21 PM
by scottad73
Last post September 06, 2010, 05:29:13 PM
by Webbot
Last post November 02, 2010, 04:45:54 PM
by Roboteccan
