Author Topic: how to connect one servo motor to two wheels ?  (Read 5502 times)
Offline ibotTopic starter
« on: May 16, 2010, 09:50:53 AM »
So far I am mounting a servo to a wheel .. But, wondering if it is possible to use one servo motor .. to connect to two wheels? So, when the servo mount rotates .. two wheels will rotate..
0----0
0----0
Imagine the above dia as wheels :) .. so, I want to connect two wheels in such a way .. but, use a single servo motor to rotate them. Please let me know how to do this.
Greatly appreciate any help !! Thanks !!
Offline Razor Concepts
  • Helpful? 53
Re: how to connect one servo motor to two wheels ?
« Reply #2 on: May 16, 2010, 11:18:14 AM »
Thanks for the link. It really looks great !!
I googled it and did not found any though .. wondering if I can find this as off-the-shelf product :) ..
Thanks !!
  • Helpful? 53
« Reply #3 on: May 16, 2010, 12:22:40 PM »
Get two gears, put one on the axle, one on the servo, and you are done?
You can't buy this as an off-the-shelf product.
If you need help constructing this, give us more information on the specifications of everything you need
« Reply #4 on: May 16, 2010, 10:11:19 PM »
bot design: [O= omni wheels]
 ---- O ----
O              O
| ___O____|
-> I am planning to use omni wheels. The bore diameter of the wheel is 3/8th of an inch. So, my axle diameter will be 3/8th inch dia too ..
-> length between two wheels is 12 inch on one side and 8 inch approx on other side
-> actually, I used HS311 and HS422 earlier. I don't know how to tell its capacity ... but, HS311 would be perfect for this one too .. so, I really like to use 1:1 gear ratio with this servo if possible ..
Questions:
1. wondering how to fix the gear on a axle ? I mean .. how can we make it not to move freely to left/right on axle.
2. My servo shaft should use a gear as a mount ? and that gear will be attached to the other gear on axle? am I right?
3. currently I have 4 wheels of same length. If you see the above design, it needs 2 axles. But, those 2 axles will have a collision :) as all the wheels are of same length. wondering, if there is a way to address this problem?
Greatly appreciate your help !! Please let me know if you have any questions or need more information.
  • Helpful? 53
« Reply #5 on: May 16, 2010, 10:15:05 PM »
It would be much easier to put one servo on each wheel to avoid the axle conflict.
Go to www.servocity.com for axles/hubs/mounts etc etc. Kind of expensive but very high quality.
Last post October 06, 2009, 04:52:41 PM
Last post February 24, 2010, 08:36:30 PM
Last post October 18, 2011, 01:35:11 PM
by newInRobotics
Last post October 12, 2012, 02:37:41 PM
by misrobot
