Author Topic: RC Sumo Robot (newbie)  (Read 3880 times)
Offline LynnetteTopic starter
« on: May 17, 2007, 01:50:39 AM »
Hi i'm currently doing a project on RC sumo robot and i would need some advice.
which type of wheels would be better for a 2 wheeled robot, with more friction?
« Last Edit: May 17, 2007, 01:51:47 AM by Lynnette »
Re: RC Sumo Robot (newbie)
« Reply #1 on: May 17, 2007, 08:55:16 AM »
http://www.societyofrobots.com/robot_sumo.shtml
I used foam wheels.
Basically you want the highest coefficient of friction between your wheel material and the floor material. The coefficient of friction can be easily determined by looking up the charts.
For how to calculate it, and a friction chart, check this out:
http://www.societyofrobots.com/mechanics_statics.shtml#friction
Offline JonHylands
« Reply #2 on: May 17, 2007, 09:38:36 AM »
http://www.huv.com/miniSumo/seeker3
I used poured (molded) polyurethane. It makes for very sticky tires - if you put my robot down on a piece of paper, and then pick it up, it will pick up the paper as well, stuck to the tires.
You have to keep the tires very clean (with rubbing alcohol) though.
- Jon
« Reply #3 on: May 20, 2007, 07:36:55 PM »
thank you guys! :D
« Last Edit: May 21, 2007, 12:59:29 AM by Lynnette »
Last post August 04, 2007, 04:28:35 PM
Last post December 09, 2011, 10:26:09 AM
by tyler555
Last post January 20, 2012, 08:19:11 AM
by billhowl
Last post June 16, 2012, 08:50:16 AM
by firatdede
