Author Topic: Infrared heat sensor use.  (Read 697 times)
Offline Hawaii00000Topic starter
« on: May 20, 2010, 10:26:59 AM »
 Can any one help me with wiring the Directional Infrared Radial Sensor on this site: http://www.futurlec.com/PIR_Sensors.shtml
The spec sheet has the has 47k resistor a between the gnd and signal and an amplification circuit, are both these necessary for a microcontroller?
Heres the specs : http://www.futurlec.com/PIR_D203S.shtml
-Paul Dirac
Its Hawaii Five-O. Get it?
  • Helpful? 84
Re: Infrared heat sensor use.
« Reply #1 on: May 20, 2010, 12:14:43 PM »
Yes. The resistor biases the internal FET and the output signal is very small therefore requires amplification.
Did you look at the PIR control chip on the Futurlec page? This might be the way to go as most of the required circuits are included, just external passive components are needed.
« Reply #2 on: May 20, 2010, 01:04:02 PM »
Would a transistor work?
Yeah, but that's not quite what I'm using the sensor for.
What about the 47k resistor between the gnd and signal? What is that for?
-Paul Dirac
  • Helpful? 84
« Reply #3 on: May 20, 2010, 07:44:56 PM »
The resistor biases the internal FET. Look at the Equivalent Circuit on page two of the data sheet.
Depending on how large of a signal you need a transistor may work. You would need to experiment to find out.
« Reply #4 on: May 21, 2010, 08:15:22 AM »
Ok thanks for the replys!
-Paul Dirac
Last post November 08, 2007, 08:30:26 PM
Last post September 15, 2008, 03:59:10 PM
Last post October 16, 2008, 10:06:31 PM
by SeagullOne
Last post January 01, 2011, 12:16:34 AM
by Redcap
