Howto: Fix Slow USB 2.0 file transfer on Windows XPSeptember 29, 2008 — JulieUSB storage devices can be optimized for either quick removal or performance. If optimized for quick removal, data transfer can potentially be reduced to a crawl. To optimize your USB drive for performance: Right click on the USB drive and select propertiesSelect the Hardware tabUnder All Disk Drives, highlight your USB drive and select PropertiesSelect the Policies tab and select Optimize for performance.Press OK twice, and your transfer speeds should increase dramaticallyNote that when your drive is optimized for performance you’ll need to use the Safely Remove Hardware icon in the taskbar to eject the drive – otherwise you’ll risk corrupting your data by just removing the drive from the port.
Started by ukesh Misc
Started by Admin Software
Started by pk44 Software
