Author Topic: Servo Jitters  (Read 802 times)
Offline redruffTopic starter
Servo Jitters
« on: May 21, 2010, 07:41:28 PM »
Hello,
I need to use a linear servo so I got a hold of this one
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10951
The problem is..when I suppply 6V power from  a battery pack it jitters really bad.
I hooked it to a stamp and I get it to move but I can never get the jitters out of it.
Any ideas?
What is under the shrink tube? Is it a PWM conversion circuit and could that be causing the problems?
Re: Servo Jitters
« Reply #1 on: May 21, 2010, 08:49:01 PM »
Any ideas?
First thing that should spring to mind when having a defective device would be to contact the seller about it ASAP.
Again, the seller have a chance of knowing. How should others know, unless they have this very servo and want to possibly destroy it to tell you?
Contact the seller and ask for a correctly working device.
Re: Servo Jitters
« Reply #2 on: May 21, 2010, 08:52:42 PM »
I don't think its defective...dude..
The circuit under the shrink tube is a common circuit..I've seen them on other servos...I believe it is a PWM filter or conversion circuit.
Thanks for the help!
Re: Servo Jitters
« Reply #3 on: May 21, 2010, 09:16:00 PM »
Well,... Dude... If it doesn't behave as it should, it's defective in my book, but if you think it's not, why do you ask?
You have a servo signal into the heat shrink and a DC motor and feedback pot hanging on the other end, so it isn't really rocket science to claim that it's not a PWM filter, but the servo controller proper, converting the servo signal to a servo position with position feedback from the (linear) pot under the slider.
No skin of my back, but if you don't wanna return it for a swap, you'll have to live with the jitter, if it's not your servo signal that is jittery.
Re: Servo Jitters
« Reply #4 on: May 21, 2010, 10:25:44 PM »
problem solved,
thanks
