Author Topic: Shared Power Supply  (Read 571 times)
Offline z.s.tar.gzTopic starter
  • Linux Guru
Shared Power Supply
« on: May 26, 2010, 05:43:40 AM »
I need to use the same power supply for both my servos and my mcu.
Right now my basic system is:  Solar > LDO Regulator > Supercapacitors > Servos -and- > Charge Pump > mcu and ir sensors.
When I run it though I don't get the full 5.0V out of the charge pump for the mcu. If I use batteries for the servos and seperate them from the power then I get 5.0V on my charge pump which makes everything fine for mcu timing and whatnot.
Is there any way I can fix this to where I only have to use the capacitors?
Offline Cristi_Neagu
Re: Shared Power Supply
« Reply #1 on: May 26, 2010, 06:29:08 AM »
You'll have to tell us for what maximum voltage the capacitors are rated for. Even with an LDO, you need at least 5.6V to get a stable 5V after it.
Also, what voltage does the solar panel outputs?
Last post December 16, 2006, 09:28:49 PM
by Militoy
Last post January 11, 2009, 07:12:02 AM
by Tomomastchi-project
Last post March 11, 2009, 01:50:25 PM
by dellagd
Last post August 13, 2009, 10:47:09 AM
