Author Topic: Axon II Questions.  (Read 801 times)
Offline totalisTopic starter
Axon II Questions.
« on: May 29, 2010, 06:45:22 PM »
On the Axon II,
What is the SS Pin?
What resistance values go before the LCD Number Display?
What is the Pin out of the ISP Programming Header?
Where can i get hold of the oscillator?
Where does the shunt go?
What does the push switch do?
Where are the Caps connected, by Caps, i mean the large ones top Right and Bottom Left also one lust to lest of Top right?
what usb chip is it?
Thanks all
T
« Last Edit: May 29, 2010, 07:22:14 PM by totalis »
Re: Axon II Questions.
« Reply #1 on: May 29, 2010, 07:21:59 PM »
Update:
Have found the USB chip on Digikey. Cost ~£2 :)
Would an acceptable Crystal be http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=X433-ND ?
also called the ECS-160-S-4
T
« Reply #2 on: May 29, 2010, 08:45:55 PM »
All of those questions you can answer by simply reading the ATmega640 datasheet, glancing at the Axon II manual, and a google search. ;)
The resister array is 180 ohms.
That crystal isn't SMD, but it'll work. Just follow this tutorial to select capacitors:
http://www.societyofrobots.com/microcontroller_xtal.shtml
« Last Edit: May 29, 2010, 08:47:53 PM by Admin »
Last post September 18, 2011, 06:32:47 AM
Last post October 29, 2009, 01:25:05 PM
Last post November 11, 2009, 09:27:08 PM
Last post August 29, 2010, 07:15:29 PM
by Andyspins
