Author Topic: errors in TPA81 initialization code in Webbtolib  (Read 1244 times)
Offline teoxanTopic starter
« on: May 31, 2010, 12:39:08 AM »
I got two errors when initializing the TPA81 in the new Webbotlib.
"../Servos.c:31: error: extra brace group at end of initializer
../Servos.c:31: error: (near initialization for 'tpa.temperature')
below is the part of code I got these errors.
#include "C:\My_Robot\WebbotLib\Sensors\Temperature\Devantech\TPA81.h"
Devantech_TPA81 tpa=MAKE_Devantech_TPA81();
Any help would be much appreciated.
Offline Webbot
  • Helpful? 107
Re: errors in TPA81 initialization code in Webbtolib
« Reply #1 on: May 31, 2010, 06:19:07 PM »
Thanks for the 'heads up'.
To fix your problem: then write the code in the same way as Project Designer does ie specifying the default I2C address:
Devantech_TPA81 temperature = MAKE_Devantech_TPA81_At(0xD0);
And the problem should go away.
« Reply #2 on: June 01, 2010, 01:01:58 PM »
ok,
I'll try it and let you know.
Thanks!
Last post September 02, 2008, 10:00:50 PM
Last post March 03, 2010, 01:17:31 PM
by GearMotion
Last post March 19, 2010, 12:37:08 AM
by teoxan
Last post October 19, 2010, 04:30:06 AM
by vasu
