Author Topic: parallel port logic analyzer software  (Read 2768 times)
Offline AdminTopic starter
« on: May 31, 2010, 10:35:12 PM »
Could be useful, if you have a parallel port . . .
http://www.codeproject.com/KB/system/17ChannelLogicAnalyzer.aspx
Offline amando96
Re: parallel port logic analyzer software
« Reply #1 on: June 01, 2010, 07:13:02 AM »
Pretty cool, putting it on a pen drive to install on my old computer later :)
Could it made into analog reading?
Rorcle, 60% complete
AATV, 5% complete
« Reply #2 on: June 01, 2010, 08:31:47 AM »
Nope
Offline amando96
« Reply #3 on: June 01, 2010, 09:21:24 AM »
But with an ADC, and some more code it should be possible?
AATV, 5% complete
« Reply #4 on: June 01, 2010, 10:12:11 AM »
Possible, just not with that program . . .
« Reply #5 on: June 01, 2010, 11:31:19 AM »
It would help if they had labeled the other pins (like where gnd is, etc)
Offline GearMotion
  • Helpful? 24
« Reply #6 on: June 01, 2010, 11:35:01 AM »
Ground is 18-25. The '-' symbol.
« Reply #7 on: June 01, 2010, 11:57:05 AM »
Oh, i never knew that. I always thought the port had one V+ pin.
Offline GearMotion
  • Helpful? 24
« Reply #8 on: June 01, 2010, 01:09:26 PM »
You can get 5V from the parallel port by stealing it from a data or control line set to "high" - but the current is limited.
« Reply #9 on: June 03, 2010, 07:10:06 AM »
Too bad it doesn't run under DOS or Linux, because it will fail repeatedly in any Windows, as it doesn't run in Ring0 (so any other stuff the OS gives attention to will break the flow).
Don't use it for anything serious.
Last post March 16, 2008, 10:11:05 PM
by frank26080115
Last post June 03, 2008, 05:42:27 AM
by RobD
Last post September 15, 2010, 07:12:23 PM
by madsci1016
Last post October 13, 2010, 02:39:19 PM
by KurtEck
