Author Topic: Simple robot avoider program - could you check please?  (Read 1185 times)
Offline ishkaTopic starter
« on: June 05, 2010, 03:53:22 AM »
Hello,
I'm going to make an arduino based robot that will avoid object in front of it.
The sensor will be a SharpIr GP2D120.
I'll use 2 HT-311 servo modified by myself.
While I'm waiting for the hardware, I start working on the code.
Could you check if there's any big mistake ( I tried keep it simple so I can easily figure what going wrong but would like your thinks).
Later I'll add more thing ( like scanning with a servo+ sharpIr so I can set direction and angle to turn)
Ty
// * Robot avoiding objects V1.0 4JUN10 * //
#include <Servo.h>
const int sharpPin=4; // set n° of the pin
Servo leftservo;
Servo rightservo;
Servo scanservo;
int distance=0;
int threshold=0;
int leftspeed=0;
int rightspeed=0;
int a=0;
int b=0;
int c=0;
int d=0;
int e=0;
void setup() {
  pinMode(sharpPin, INPUT); //set the pin of sharpIR and servo NB: n° of the pin are
  leftservo.attach(9);      // fictive - waiting for the board.
  rightservo.attach(8);
  scanservo.attach(7);
  setThreshold ;
void setThreshold() {  //set the threshold value doing a mean of 5 distance value
  a=analogRead(sharpPin);
  delay(40);
  b=analogRead(sharpPin);
  delay(40);
  c=analogRead(sharpPin);
  delay(40);
  d=analogRead(sharpPin);
  delay(40);
  e=analogRead(sharpPin);
  threshold=(a+b+c+d+e)/5;
void loop()
  distance=analogRead(sharpPin);
  if (distance > threshold)  {          // If no object in the way
    leftspeed=180;
    rightspeed=180;
    leftservo.write(leftspeed);      // go forward
    rightservo.write(rightspeed);
  else {
    leftspeed=135;
    rightspeed=45;
    leftservo.write(leftspeed);      // else turn right
May the Achtuche be with you...
Offline HyperNerd
  • N3rd1n80r
Re: Simple robot avoider program - could you check please?
« Reply #1 on: June 05, 2010, 06:16:53 AM »
Looks pretty good as far as I can see, apart from one thing which I think is wrong - I'm not a C genius but,
I think
  setThreshold ;
should be
  setThreshold();
Apart from that all looks perfect.
 -HyperNerd
« Reply #2 on: June 05, 2010, 09:38:38 AM »
Great. Ty for the () advice, arduino prog didn't say anything about it when it compiled.
Just another question : am I right if I think that telling my modified servo to go 180° will make it turn faster than if I tell 135 ? And that under 90° it'll turn counterclockwise ?
Ty
Offline HyperNerd
  • N3rd1n80r
« Reply #3 on: June 05, 2010, 02:07:00 PM »
That's completely correct.
A value further from the centre point (90°) will make it spin faster.
The centre value might not be 90° though, depending on how good the servo is, it could be anything from about 88° to 92°.
 -HyperNerd
« Reply #4 on: June 05, 2010, 11:53:08 PM »
OK thanks. Now just have to wait till thursday so I can start working on the hardware... I hope that volcan won't smoke the entire atmosphere once more ;-)
Last post March 21, 2006, 08:41:14 AM
by JesseWelling
Last post February 13, 2009, 12:46:03 AM
Last post January 24, 2010, 09:12:08 PM
by waltr
Last post February 16, 2013, 04:51:20 PM
by vipulan12
