Author Topic: 50$ robot questions regarding part selection  (Read 690 times)
Offline rabadswompeTopic starter
« on: June 07, 2010, 01:08:19 PM »
Hello!
I intend to buid the 50$ robot and then upgrade it to the IR rangefinder mod to make it "sumo".
I tried to source out my materials list at the local electronics store... some parts were really easy, others came back with questions...so here they are :
#1- What is the exact Sharp IR rangefinder's model number AND range ?
#2-is the 5v linear regularor positive OR negative ?
#3- Is the 220uF - 16V capacitor ok? (parts list doesn't mention V value)
#4- 340 ohm and 1,62 ohm resistor ok at 1/4V ?
#5- What LED to select (3mm or 5mm )?
#6- What is a good resitance value for the photoresistors ?
Thanks for your help
Yann
Offline amando96
Re: 50$ robot questions regarding part selection
« Reply #1 on: June 07, 2010, 02:22:10 PM »
It usually depends on What you want, but lets wait for someone with 50$ robot knowledge to answer :)
7805, 78 means positive.
if you mean 1/4 WATT, yes
up to you, i like 3mm, you might like 5mm, the mm is only talking about the diameter of the led casing.
Rorcle, 60% complete
AATV, 5% complete
Offline Choco_liger
« Reply #2 on: June 07, 2010, 05:36:25 PM »
1#
Well I got a 4cm to 30cm range. I haven't quite tested it yet but as long as you have an appropriate range. Like, don't get something 80cm - 100cm for example (assuming they exist).
3#
Yeah that should be fine. I think the only thing that matters is the amount of micro farads anyway unless it's really low.
6#
Well 20k for the photo resistors. I think that was the one for mine. Unless your meaning the value of the resistor attached to them. In that case about 1.62K.
Offline Alfa_Zulu
« Reply #3 on: June 08, 2010, 11:17:14 AM »
hey
    As far as im aware it doesn't matter, just choose a range that suits you, around 10cm-50cm
    Positive voltage
    The voltage doesn't matter, normal rule of thumb is higher rated voltage the better (but keep it realistic for you project)
    like don't use a 450V cap in a 5V circuit like me lol (that's all they had left in stock).
    I think you mean 1/4watt which should be completely fine
    as already said this is just the casing diameter, only worry about it if your fitting it into a housing.
I know most of these were already answered but I'm just offering my opinion  ;)
    Alfa.
Last post November 13, 2008, 08:32:36 PM
Last post October 02, 2008, 08:03:21 PM
by Trumpkin
Last post March 26, 2009, 04:56:46 AM
Last post February 24, 2011, 02:22:46 PM
by nickc
