Author Topic: Robot Fish Battery  (Read 2122 times)
Offline voyager2Topic starter
  • Helpful? 6
  • Behold! The Impossible Triangle of robotics!
Robot Fish Battery
« on: June 07, 2010, 10:20:19 PM »
Hi all,
I have decided to make my own robot fish.
Bellow is a YouTube video of my inspiration.
Small robot fish powered by solid polymer fuel cell : DigInfo
And here is the URL
http://www.youtube.com/watch?v=bVTpINHJeaY&feature=PlayList&p=B82E7D0174883419&playnext_from=PL&index=5I have everything worked out except the battery and how to protect the ATMega8 chip from magnetic-radiation.
My first thought was lead, to protect the chip then i ran out of ideas.
For the battery i though of Li-Ions or 10F super capacitors :o(available from Little Bird Electronics)
« Last Edit: June 08, 2010, 04:12:17 AM by voyager2 »
And it was good.
Offline Razor Concepts
  • Helpful? 53
Re: Robot Fish Battery
« Reply #1 on: June 08, 2010, 03:52:51 AM »
The mega8 should not be affected by magnetic radiation - i have swiped neodymium magnets right over these chips with no effect.
  • Helpful? 6
« Reply #2 on: June 08, 2010, 04:07:12 AM »
Thanks, now just the battery...
And it was good.
Offline Joker94
  • Helpful? 26
« Reply #3 on: June 08, 2010, 06:03:52 AM »
a couple of 3v coin batteries should suffice like the following ones (just as an example)
http://en.wikipedia.org/wiki/Button_cell
they are really small so it should not take alot of weight or room. i havent used them personally but i have seen them used in micro swarm bots. Google micro bots and you might find some useful stuff (i say this as i gather you want the electronics to be pretty small).
  • Helpful? 6
« Reply #4 on: June 08, 2010, 07:17:56 AM »
The Electronics are based on the $50 robot :o with an additional two transistors to drive the tail.
I am using TIP 31B/C Power Transistor NPN, will these suffice?
http://www.dse.com.au/cgi-bin/dse.storefront/4c0e3cac02febe38273fc0a87e01067e/Product/View/Z2020
Thanks for all the help so far, Stay Tuned!
And it was good.
  • Helpful? 84
« Reply #5 on: June 08, 2010, 07:24:28 AM »
Just an FYI on :
Lead will do nothing to a magnetic field. Lead is good to block nuclear radiation however.
To shield something from a magnetic field one needs to use a material that has a high magnetic permeability such as Iron and some other materials. and the shielding material shape needs to be carefully designed.
But as Razor said, "The mega8 should not be affected by magnetic radiation" ans so it is not needed.
« Reply #6 on: June 08, 2010, 03:42:02 PM »
For batteries, you might wanna consider Zinc/air (if you have enough air abord for the runtime).
Else, Lithium cells in some form would be the sensible choice.
  • Helpful? 6
« Reply #7 on: June 08, 2010, 09:08:03 PM »
Hi Soeren, I thought of Li-Ions but I remembered Admin's battery tutorial.
"Lithium forms large quantities of hydrogen when put in contact with water."
I an more concerned with the battery exploding than frying my electronics!
I'll consider sealing it with silicone-rubber.
« Last Edit: June 08, 2010, 09:11:26 PM by voyager2 »
And it was good.
« Reply #8 on: June 24, 2010, 08:02:50 AM »
I'd recommend just using a NiMH battery.
If you really really need high current, use LiFe. Its like a Lipo, but without the thermal runaway issue and half the mAh.
« Reply #9 on: June 24, 2010, 06:44:29 PM »
What do you think happen to electronics in general when it gets wet?
A fish should be watertight (or else it would drown ;D)
  • Helpful? 6
« Reply #10 on: June 25, 2010, 03:54:45 AM »
...A fish should be watertight (or else it would drown ;D)
 :) :D ;D
What do you think happen to electronics in general when it gets wet?...
I didn't mean the electronics, I got 10 free sample ATmega 168s from ATmel so their not a problem,
I meant the battery.
O.k. this did sort of sound concerning, but the battery is sealed anyway
If water gets in whos to say I don't make a model Hindenburg ;D
And it was good.
  • Helpful? 53
« Reply #11 on: June 25, 2010, 05:26:11 AM »
Lipo cells are complegely sealed. You can drop one in water and it won't explode. Putting it in water is actially one method of disposing the battery. This is also why cell phones dont explode when dropped in water  :D
« Reply #12 on: June 25, 2010, 07:10:46 AM »
Drop it in water and let the two battery leads short. Then say that :P
(assuming the Lipo doesn't have some form of built in short protection)
« Reply #13 on: June 27, 2010, 07:32:00 PM »
Why would that be any bit worse than doing it out of the water - sounds a bit reckless to me, whatever the ambient fabric.
« Reply #14 on: June 28, 2010, 07:26:30 AM »
ehhh I didn't explain myself properly . . . was implying that a water leak in the fish could result in the leads shorting . . . and as soon as the battery waterproofing melts off, thats when the fun starts ;D
« Reply #15 on: June 28, 2010, 08:05:57 PM »
[...] was implying that a water leak in the fish could result in the leads shorting . . .
Shorting? You must have very very very low impedance water in your end of the world ;D
As I didn't see any "Folks, don't try this at home", I'll see if I can find a suitable "fish size" LiI-on, when I get past my home some time this week.  This needs some hard evidence - Would a salinity of 40g/l (sea water is around 35g/l) be OK, or were you referring to The Dead Sea?  ;)
Lots of young people carry their Li-Ion driven cell phones in their trouser pockets, which means they are often very steamy inside (i.e. an RH of around 99%) during the summer. I have seen plenty of gold plated PCB's with the copper oxidizing through the gold at every trace edge, from sweat that is slightly less saline than sea water - I haven't heard of any spontaneous combustions though.
Too bad I gave up having an aquarium - that would have been the ultimate test lab, with bright colored cat food swimming around the potential nuke  ;D
Well, I'll see what setup I can come up with.
  • Helpful? 6
« Reply #16 on: June 28, 2010, 08:32:10 PM »
:D
I still have my fish tank, with one googly eye Goldfish(called Google),  and he's survived for nearly 1 year. :)
Thanks to my expert care and my second favourite website, kokosgoldfish.com he should survive another year!
And it was good.
« Reply #17 on: June 28, 2010, 09:33:19 PM »
So, it wouldn't be rude to tell you to "go fish" if you need info?  ;D
« Reply #18 on: June 29, 2010, 07:12:24 AM »
Please film it! Have the leads right next to each other, of course . . . Various websites listed sea-water resistance from 0.5 ohms to 200 ohms. For a fully charged 7.2V LiPo at the lower end of resistance, you'd get a 15W short.
If someones pants get *that* wet, he already has other problems ;D
Actually, I saw one guy freak out in front of me and run to the bathroom, then came out a bit later saying the lead-acid AA batteries in his pocket somehow began leaking. He then went on to explain that it probably happened because its so hot in his pants . . . not sure what he meant by that . . .
Last post November 15, 2006, 07:49:47 PM
Last post February 26, 2008, 02:02:28 PM
Last post March 04, 2008, 05:52:11 PM
by HDL_CinC_Dragon
Last post April 22, 2009, 08:50:27 AM
by austin
