Author Topic: hyperterminal to controll robot  (Read 707 times)
Offline javilaTopic starter
« on: June 07, 2010, 10:47:31 PM »
Hi: I have the 50 $ robot with the uart working, I connected the robot to the computer to be able to see the values
of the sensor, everything works fine.. Now I want to be able to controll a set of leds from hyperterminal, do I have to change something on the initializations or the same thing that works for sending data works for receiving?
Basically the code uses the port d as output.
DDRD = 0xFF;  //configure all D ports for output. If I am going to be receiving data on the RX input.. do I need to change
that pin to input or that does not matter when you use uartGetByte()????
Re: hyperterminal to controll robot
« Reply #1 on: June 08, 2010, 09:44:11 AM »
Nope, no need to change the port inits. Rx is always an input and Tx is always an output.
« Reply #2 on: June 08, 2010, 09:55:01 AM »
nice, thanks
Last post February 19, 2007, 03:16:09 PM
by JesseWelling
Last post April 18, 2008, 03:36:29 PM
by paulstreats
Last post December 26, 2008, 12:33:42 PM
by Geir
Last post December 13, 2010, 12:15:25 PM
by alex2988
