2
Author Topic: what is required to port webbotlib to run on a new avr chip?  (Read 1306 times)
Offline romickTopic starter
I have a MCU based on ATMega128L. What sys header file should I use? If there is no required header, what file should I use to base new header on it? What should be changed in the file for proper execution on different MCU?
  • Helpful? 111
Re: what is required to port webbotlib to run on a new avr chip?
« Reply #1 on: June 12, 2010, 10:25:51 AM »
Give me some time to check the datasheet and I'll get back to you
  • Helpful? 111
« Reply #2 on: June 12, 2010, 11:10:21 AM »
The 128L has the same datasheet as the 128
So just try including
sys/atmega128.h
