Author Topic: The $50 robot using an Arduino  (Read 2221 times)
Offline AnorocTopic starter
« on: June 10, 2010, 01:39:40 PM »
I found this site back in 2008 and got all geared up to start building the $50. Shortly after getting all my parts, I had a large work project come up which led to me moving. I ended up having to abandon the robot project -- Until NOW :P Unfortunately, I have lost the  ATmega8, I purchased, Somewhere in my move. Today, I received an Arduino and was curious.. Is there any info / tutorials / point in the right direction that might explain how to replace the original electronics design with an Arduino Duemilanove in creating the "$50 robot"?
Re: The $50 robot using an Arduino
« Reply #1 on: June 10, 2010, 02:29:39 PM »
http://www.societyofrobots.com/member_tutorials/node/240 The roboduino is exactly the same except for the extra two rows of pins. Should help you a bit.
« Reply #2 on: June 10, 2010, 08:26:26 PM »
Sweet! Thanks,
While reading thru the roboduino tutorial, it stresses the programming is ONLY for the roboduino. Is this true, even if using the Arduino?
Offline Razor Concepts
  • Helpful? 53
« Reply #3 on: June 10, 2010, 09:46:34 PM »
Arduino is the software development environment. Roboduino is the physical board, and it runs the Arduino code. So code for the Roboduino works perfectly in all the other Arduino boards.
« Reply #4 on: June 10, 2010, 09:58:36 PM »
Although I saved some cash buying the arduino board, I kinda wish I went ahead and sprung for an Axon. Mainly because I'm so noobish, right now.
« Last Edit: June 11, 2010, 10:58:39 AM by Anoroc »
Offline Xyver
« Reply #5 on: June 19, 2010, 01:33:11 AM »
Arduino is better for noobs i think.  I'd imagine that the Axon would be getting too complicated too fast. I have my 50$ robot i made with arduino, and I already messed around and made code for it, so pm me if you like.  Im also updating it with ultrasonic and Ir rangfinders within a week or 2, so you can get that code to if you like.
