Author Topic: need male 4mm bullet plug to female hitec adapter  (Read 1140 times)
Offline AdminTopic starter
« on: June 14, 2010, 02:37:54 PM »
I have a battery with a female 4mm bullet plug on it.
But I need to have a Hitec female plug to go into my male headers.
I'm looking for an off-the-shelf adapter(s) to do this.
Know where I can find one? Its ok to need two adapters for it.
Its not ok to suggest me to make my own (I have my reasons) :P
Re: need male 4mm bullet plug to female hitec adapter
« Reply #1 on: June 14, 2010, 04:08:07 PM »
Hmmmm browsing around, it appears websites can't tell the difference between a banana connector and a bullet connector.
This battery says bullet connector, but considering the length, I'd almost say its a banana connector:
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=10309&Product_Name=Turnigy_4500mAh_2S2P_30C_LiFePo4_Pack
Anyone know?
« Reply #3 on: June 14, 2010, 10:27:17 PM »
Is it OK to suggest swapping the connectors directly on the battery then?  ;D
Using an adapters is just adding one more thing that can go wrong.
If you need lots of them, you may be able to order them with a female Hitech  connector.
« Reply #4 on: June 15, 2010, 08:09:10 AM »
bullet:
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9283&Product_Name=HXT_4mm_Gold_Connector_w/_Protector_(10pcs/set)
i have a set of those same connectors if you need more info
Well, those are the longer banana type plugs.
I'm not 100% sure which the battery uses, so I bought the ones you suggested, and these as well:
http://www.all-battery.com/twopairsof4mm-bulletconnector.aspx
Last post December 12, 2007, 10:39:39 AM
by rox2007
Last post December 26, 2008, 08:29:22 PM
by Webbot
Last post August 30, 2010, 03:21:48 PM
by Metal Slug 2
Last post November 30, 2010, 12:41:25 PM
