Author Topic: Voyager2's Robot Fish  (Read 6994 times)
Offline voyager2Topic starter
  • Helpful? 6
  • Behold! The Impossible Triangle of robotics!
Re: Voyager2's Robot Fish
« Reply #60 on: September 03, 2010, 06:34:23 AM »
Hi All,
I've been researching different ways of propelling my fish, all 4 of my electromagnet attempts have failed, and instead I'm going to use a servo.
I have therefore emptied my money box to buy this little guy from a local hobby shop:
HS-65HB Mighty Feather servo.
Came with 2 extra horns and 4 screws for mounting, a good $28 spent!
Haven't powered it up yet but apparently it can supply 2.2kg-cm @ 6v
And it was good.
Offline Joker94
  • Helpful? 26
« Reply #61 on: September 03, 2010, 06:59:32 AM »
That servo when used properly is great quality. it is popular at the model aeroclub i am a member of. it is commonly used in small nitro planes with great results.
What are your plans for this drive systems?
looking forward to seeing the design!
  • Helpful? 6
« Reply #62 on: September 03, 2010, 07:19:02 AM »
I'll upload a CAD later but the general idea is that a little piece of solid core wire is threaded through a hold in the horn, that bit of wire is attached to a lever that drives the tail.
Since its so small I'd love to see a continuous rotation mod for it...
And it was good.
Offline Joker94
  • Helpful? 26
« Reply #63 on: September 03, 2010, 07:33:52 AM »
I have heard that they can be a bit temperamental. the most important thing to take into consideration the structure of the gear. just because of the size they become a lot harder to work with. but if you do it bit by bit with a file or something similar and put little stress on the servo then you shouldnt have a problem.
have a look in the memebrs tutorials section as i think there is a tutorial on how to mod a micro servo like yours.
Good luck
  • Helpful? 6
« Reply #64 on: September 03, 2010, 07:43:16 AM »
I'd never really need to mod it, just thought it would be cool to see one modded
Here's the CAD I through together:
http://www.filesend.net/download.php?f=fc8a0ad02db64c03bb20be6f2bd983c5
The servo is over-sized, and the little wires coming out of the horn are not quite right.
The little "plate" on the end of those wires is hinged (that wire/rod thing is the pivot) and the tail is attached directly to it.
And it was good.
Offline Joker94
  • Helpful? 26
« Reply #65 on: September 03, 2010, 08:04:29 PM »
it all looks good, looking forward to seeing the build.
Last post November 15, 2006, 07:49:47 PM
Last post March 04, 2008, 05:52:11 PM
by HDL_CinC_Dragon
Last post April 22, 2009, 08:50:27 AM
by austin
Last post June 29, 2010, 07:12:24 AM
