Author Topic: What exactly JST female connector and pins do I need for Sharp IR range finder?  (Read 1147 times)
Offline huevonTopic starter
Hi everybody,
Does anyone know what exactly JST connector uses Sharp IR range finder. Already checked about 5 different datasheets but didn't say what the connector is. There are pre-crimped cables sold on-line but they cost £2 each + delivery. UK shop would do best (less $$$££££ for delivery), but digi-key and mouser also can do. I need the female pins and housing.
Thank you all
Chris
  • Helpful? 111
You can always solder wires straight onto it rather than use a connector
He-he thought so, but that is profanation
btw might do it this way
It is a now standard 2mm spaced latching connector. Google will find many sources.
http://www.jst.com/
http://www.jst-belgium.be/
I just solder regular 1/10" pinheaders in, then I don't need strange connectors (you may be able to find the JST connectors connectors in old VCR's or photocopiers etc. made in Japan)
JST is a Japanese standard.
Offline galannthegreat
Kurt
