Author Topic: I2C pins on AxonII  (Read 704 times)
Offline Aberg098Topic starter
I2C pins on AxonII
« on: June 24, 2010, 08:45:25 AM »
Quick newbie question again:
So which pins on the AxonII corresponds to the SCL and SDA for the I2C connection?
I can see where I2C is labelled on the board, I also know that the outermost (ground) connection is not used.
Re: I2C pins on AxonII
« Reply #1 on: June 24, 2010, 09:36:12 AM »
Have a look at the schematic, it'll be obvious. Unfortunately I couldn't cram all that text directly on the board :-\
« Reply #2 on: June 24, 2010, 09:41:18 AM »
If you mean this schematic:
http://www.societyofrobots.com/axon2/downloads/axon2_schematic.pdf
I completely fail to see how this is obvious.
Offline paulstreats
  • Helpful? 20
« Reply #3 on: June 24, 2010, 09:53:19 AM »
Under the "special headers" part, the first is the I2C header. SCL is in the middle and SDA is on the outside(the opposite one from the GND)
« Reply #4 on: June 24, 2010, 09:57:38 AM »
Thank you!
Last post February 08, 2009, 09:08:53 AM
by Joesavage1
Last post May 06, 2010, 05:30:24 AM
Last post July 02, 2010, 06:58:58 PM
by dellagd
Last post September 12, 2010, 08:41:56 AM
by tipipliou
