Author Topic: parallel port problem  (Read 2563 times)
Offline vbnandu86Topic starter
« on: May 21, 2007, 08:52:22 AM »
i have installed win XP on my system.To enable myself to program using the parallel port,I installled M.S Virtual PC,on that(virtual computer) i have installed Windows 98.
I have been able to output to the parallel port using turbo C++(Borland 3.0) compiler with the following statement.
outportb(0x378,0xff)//This makes all the pins high.
Everythings fine till here.
 :'(..................|||THE PROBLEM|||.............. :'(
i know the pins 10,11,12,13 and 15 can be used for inputting data from the parallel port by giving a logic 1(2.47V to 5 V).i am not able to read the data from any of them.Every time it shows a value of 127 for the following statements.
#include<stdio.h>
#include<conio.h>
#include<dos.h>
 void main()
  int i=0;
  i=inportb(0x379);
  printf("%d",i);
  getch();
The multimeter reads 4.8V for the lead i am going to insert into the pin 10.
If anyone can identify where i am going wrong,please reply and any advice is always welcome.
Offline iNFINITE
Re: parallel port problem
« Reply #1 on: May 21, 2007, 10:05:01 AM »
You can program the parallel port in XP also,Just install this Userport driver: http://www.embeddedtronics.com/public/Electronics/minidaq/userport/UserPort.zip
Correct me if i am wrong: Have you only tried giving 4.8V to pin 10?
Then..
When giving 4.8V to pin 10(S6) ,and the other Status port pins(11,12,13,15) being left unconnected.
so in the status port(0x379):
S7(pin11)=0(as it is hardware inverted)
S6(pin10)=1
S5(pin12)=1
S4(pin13)=1
S3(pin15)=1
S2,S1,S0 are not available for use and they are all high(1)
So ur status port is 0111 1111(binary) =127
Try connecting the pin 10 to gnd, then ur reading should be 0011 1111(binary)=63
« Reply #2 on: May 26, 2007, 11:53:37 AM »
thanks infinite!!! you were infinitely helpful!!!!!! ::)
Last post July 16, 2007, 05:55:25 PM
by dunk
Last post August 25, 2007, 10:46:25 AM
by Nyx
Last post March 03, 2008, 10:22:08 AM
by dunk
Last post May 04, 2008, 08:41:50 AM
by izua
