Author Topic: Card Box Robot Chassis  (Read 2008 times)
Offline RaevenTopic starter
« on: June 26, 2010, 10:12:19 PM »
I have started the $50 robot. So far I have constructed a chassis from an old Deck Box (like the ones you put Yugioh cards into). So far the only electronics on it are the two mounted servos. I plan to house the battery and circuit board inside of the box. On the front of the robot are two holes for the photo-resistors. However, having the two photo-resistors so close to the ground; inevitably, leads to them looking at their own shadow. I would like to know could this lead to a problem?
Here is a link to the deck box I used: http://www.criticalgamers.com/archives/pictures/DeckBox.jpg
The two holes are drilled into the white tab on the top of the box.
« Last Edit: June 26, 2010, 10:15:58 PM by Raeven »
Offline dellagd
Re: Card Box Robot Chassis
« Reply #1 on: June 27, 2010, 07:10:28 AM »
well, it might. Depends on how close they are to the ground an if they are pointing down.
Have you put together the $50 board yet? Just try it out! If it does interfere, move them up!
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
Offline chelmi
  • Helpful? 15
« Reply #2 on: June 27, 2010, 07:19:46 AM »
I think you misunderstood how photo-resistor work. They don't "look" at something, they sense the light hitting their surface. I don't see how they could project a shadow on themselves.
« Reply #3 on: June 27, 2010, 08:20:09 AM »
Pointing them at the ground allows them to read the light that reflects off the ground onto their surface.
Offline Razor Concepts
  • Helpful? 53
« Reply #4 on: June 27, 2010, 08:30:25 AM »
Add LEDs to shine at the ground, getting rid of the shadows.
Offline random robots
  • he drives worse than my robot... thats sad
« Reply #5 on: June 27, 2010, 08:35:05 AM »
wouldn't the led interfere with the readings from the ambient light?
this is a signature.
  • Helpful? 53
« Reply #6 on: June 27, 2010, 09:09:03 AM »
That brings us around to the question, why would you would you want to measure the ambient light of the ground  ???  I assumed that by measuring the light reflected from the surface you wanted to do line following.
« Reply #7 on: June 27, 2010, 09:15:39 AM »
i was thinking it was a photovore. whoops
Offline dellagd
« Reply #8 on: June 27, 2010, 11:26:15 AM »
can you not just move the photo resistors higher up on the robot?
point then up?
I Won!
Offline Xyver
« Reply #9 on: June 27, 2010, 05:40:22 PM »
or like a 45 degree angle forewards?  then itll look a few centimeters infront of your bot, instead of beneath it.
Offline WhomBom
« Reply #10 on: July 01, 2010, 03:28:20 PM »
just a loose remark from a fellow just-started robot builder; don't try to cramp too much parts into a small space! you'll always forget something and than you will be happy with a bit of extra space  ;D
Offline Alfa_Zulu
« Reply #11 on: July 06, 2010, 12:32:58 AM »
as you might notice most light sources come from above, off the top of my head we have, the sun, lights in a house, torch and etc.
so point them almost straight up, if it drives into a shadow under a table it'll still turn around. this will cause your reading to be more accurate and less chance of it not sense the light at all  :)
Last post January 31, 2009, 11:54:03 PM
Last post May 12, 2010, 09:23:22 AM
by corrado33
Last post February 01, 2012, 02:04:48 AM
by kyrill
Last post September 24, 2012, 07:47:43 PM
by SlightlyNormal
