Author Topic: Nimh battery pack??  (Read 3043 times)
Offline NOOBinDistressTopic starter
Nimh battery pack??
« on: May 21, 2007, 03:58:14 PM »
Ok so I am done the board and am hooking up the battery. I have a 9.6v Nimh battery that used to be for a old rc car. Can I hook it up to the board and will it work? How do I do it because I can just hook it up like in the picture because it has a plastic thing on plug in end. So it will go into rc car jut not onto little clip on board. Thanks please help
This is for the 50 dollar projects :)
PLEASE HELP!!!!!!!!!!!!!!
« Last Edit: May 21, 2007, 04:59:30 PM by NOOBinDistress »
Re: Nimh battery pack??
« Reply #1 on: May 21, 2007, 05:32:03 PM »
Sorry, a 9.6V battery will not work. The servos are likely to fry if you give them much more than 6V . . .
« Reply #2 on: May 21, 2007, 05:47:03 PM »
Well I have one of those square 6v battery packs how can I hook that up to my bot?(it has no wires)
« Reply #3 on: May 21, 2007, 06:26:38 PM »
Offline ed1380
« Reply #4 on: May 21, 2007, 07:43:15 PM »
I used one like that, after I made a little box for it. it was a PITA making the box, and if looks don't matter just hack up a rc car for the slot/cartridge receiver.
« Reply #5 on: May 21, 2007, 08:05:17 PM »
YOu said its all in the instructions? You are not using one of the square battery 6 volt things in your turorial. Like I said mine has no wires it is just a rectangle, just like this one:RC CAR BATTERY PACK AND CHARGER 6 VOLT NI-CD It is on ebay but it is NI-Cd and it is like the one I have rectangular. Please look at it. Just copy and paste that into ebay. I am sorry I could not get the link I can not get the link bar up on this stupid computer. >:(
Please help thankyou.
« Last Edit: May 21, 2007, 08:06:11 PM by NOOBinDistress »
« Reply #6 on: May 21, 2007, 08:13:08 PM »
Oh I thought you meant the robot had no power wires . . .
Can you solder wires on to it?
« Reply #7 on: May 21, 2007, 08:19:56 PM »
Idk should I try it And where would I have to solder them ? Would it matter?Would it work?
« Reply #8 on: May 21, 2007, 08:28:54 PM »
Hmmm so soldering on to batteries is kinda hard. The problem is that they absorb the heat so fast your solder wont melt. And if it takes you a long time, you could damage the battery.
The trick is to turn your soldering heat up really high so you can melt the solder before the heat dissipates. Coating it with lots of flux is also good. If you dont have a good soldering iron perhaps you should take ed's suggestion . . .
You probably also should practice soldering wires onto thick peices of metal first just for practice . . .
Offline ed1380
« Reply #9 on: May 22, 2007, 04:54:47 AM »
I've tried soldering unto the battery many times before, even with a powerful gun, and it don't work.
« Reply #10 on: May 22, 2007, 05:22:18 AM »
Ok thanks . I need help ordering the battery then in link above
Offline Rolf
« Reply #11 on: May 22, 2007, 08:22:59 AM »
I have also tried soldering batteries without any luck. Seems like the battery-surface repells the solder pewter. What I did was simply taping the wires to the battery with ducttape. I have not had any problems with bad connection.
Offline ed1380
« Reply #12 on: May 22, 2007, 10:35:15 AM »
Ghetto connection FTW
just use the 9.6v battery and put it through a switching regulator, and then plug it in.
read this http://www.societyofrobots.com/robotforum/index.php?topic=776.msg4928#msg4928
« Last Edit: May 22, 2007, 10:38:11 AM by ed1380 »
Last post September 09, 2007, 09:21:30 AM
by HDL_CinC_Dragon
Last post April 11, 2008, 12:17:23 PM
by superchiku
Last post September 09, 2008, 05:31:51 PM
by TrickyNekro
Last post December 20, 2008, 09:44:56 AM
by ed1380
