Author Topic: Pull to Ground  (Read 2199 times)
Offline 123ericTopic starter
Pull to Ground
« on: May 21, 2007, 09:34:18 PM »
I am using a pic16f870 with basic and am tying to get the pins to pull to ground an sink a current but its not working for me.
thanks for any help.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Pull to Ground
« Reply #1 on: May 21, 2007, 11:49:27 PM »
The pins have to be set as output and low. This way you can sink up to 20mA of current on each pin.
If you are trying to read a sensor, you need to disable the internal pull up resistors and add an external 10k resistor between the pin and GND. The sensor will be connected to the pin and the pin will read low if no signal is received and high if the sensor is triggered.
Last post December 28, 2010, 11:22:21 PM
by koolraj09
Last post October 23, 2011, 06:20:15 AM
by hamzaman
Last post June 28, 2012, 09:05:58 AM
by Physics Fu
Last post October 04, 2012, 05:20:03 PM
