Author Topic: Axon II EEPROM in webbot lib  (Read 1111 times)
Offline dellagdTopic starter
« on: July 04, 2010, 11:43:36 AM »
I was in need for a EEPROM on the Axon II and I hear it has one built in.
I was looking through WebbotLib and I only see documentation on how to create an external EEPROM (one that you hook up to the Axon)
How would I use the one that is built in?
« Last Edit: July 04, 2010, 12:16:28 PM by dellagd »
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
Offline KurtEck
  • Helpful? 12
Re: Axon II EEPROM in webbot lib
« Reply #1 on: July 04, 2010, 05:20:57 PM »
On my Lynxmotion Brat with an Axon2, I save away things like servo offsets into the built-in EEPROM.
I simply use the functions: EEPROM_READ_BLOCK and EEPROM_WRITE_BLOCK.  code like:
// Will write the block out starting at 0... may later change to use some of the other stuff.
eeprom_write_block(&bsd, 0, sizeof(bsd));
Where the variable bsd is to a structure (BratSaveData)
Kurt
Offline Webbot
  • Helpful? 111
« Reply #2 on: July 04, 2010, 05:24:32 PM »
The eeprom functions are for reading/writing to 'on chip' eeprom space. But WebbotLib also supports external I2C and SPI EEPROM chips if you need more space.
« Reply #3 on: July 04, 2010, 05:29:57 PM »
sorry Webbot, but could you explain more?
'eeprom functions' - please explian
« Last Edit: July 04, 2010, 05:36:49 PM by dellagd »
I Won!
Offline Webbot
  • Helpful? 111
« Reply #4 on: July 04, 2010, 06:19:27 PM »
In Version 1.22 then see the eeprom section on page 32 of the manual for 'on chip' usage.
For other 'off chip' storage then see the 'Storage' section of the manual on page 255
Offline KurtEck
  • Helpful? 12
« Reply #5 on: July 04, 2010, 06:29:21 PM »
If you look at the EEPROM section in webbotlib's pdf file, it shows that these functions are not provided by webbotlib, but are part of the underlying system.  On my system eepromexplain.h is located in:
c:\winavr\avr\include\avr
What the webbotlib system files define, is the actual size of the EEPROM for each of the different processors.
As I mentioned in my previous post, I use the eeprom_read_block and eeprom_write_block functions.  There are other functions like eeprom_read_word as well.
Kurt
